trans temp?
how hot should my tranny run on my 04? unloaded and pulling 12-16k?
Once my truck warms up I run about 150-160 degrees. I am not sure about when towing heavy loads yet.
Generally its 60-80 degrees over outside ambient temps unloaded. Loaded depends but you want it to be 200 or under. The less heat the longer life of the trans
I've had 13k behind mine and never got over 175 towing on level 4 with the 6 Gun.
Contrary to what the aftermarket vendors will tell you and popular belief, the torqshift with Mercon SP is fine up to 230*. This is according to Mark Kovalesky who was a Ford transmission engineer from 1988 until 2007 and worked on the 5R110 extensively.
True it might be okay to 230, but running it to the max will shorten the life of a trans. The best advise I can give ya pistolpete is heat is always bad for a trans the less you can generate with synthetic fluids, coolers, and trans tuning for less slippage the longer the trans will last.
The light comes on at 230 degrees.
215 degrees is probably a comfortable maximum from what I have been told. |
thanks for the info. with spring coming around both of my truck will have to work alittle harder than they have over the winter.
