Oasis Trasnslation... - Ford Powerstroke Diesel Forum
Old 03-16-2008, 10:42 AM
Can somebody translate the regarding the info about the injectors, head gasket, and turbo, thanks.
OASIS RESULT:
1FTSW31P84ED60646
03/16/2008
14:19:26
FCXWS447
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
ATTENTION TECHNICIANS AND SERVICE MANAGERS:
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-04-07
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/08/2004 BUILD DATE
05/14/2004 SALE MILEAGE
00025
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
Click Here for Full Warranty History
| On-line 1878
END OF OASIS REPORT FOR 1FTSW31P84ED60646
Old 03-16-2008, 11:16 AM
DKR DKR is offline
<--Pro Cooler Racer
What I see is just a reminder to the techs to check the latest bulletins regarding the injectors, head gaskets, and turbos.
It is updated info for them before they swap any parts out and do any warranty work. If that is all the report, then it doesn't look to have any work completed on it.
Old 03-16-2008, 11:38 AM
Awesome! Thanks DKR!
Could be a possible Candidate for my first PSD...
Old 03-16-2008, 01:01 PM
Send a message via AIM to Streak
Just make sure that the reason it's being sold is because something is wrong and needs to be fixed
Old 03-16-2008, 01:20 PM
BIG TRUCK, SMALL DRIVER
That's the cleanest Oasis I have ever seen. Looks like it has either never had a problem, or the owner just didn't want to take it in if it did. If it runs good, you should be in good shape.
Old 03-16-2008, 01:28 PM
Gun Nut
There are two files that I sent - one opens with IE and has the actual shop info. I re-ran it and here is the second page:
AWS Claim Key: 1985855 Trx Code: 1 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01362 - * Name: BOB RUTH FORD, INC. Ph: 717-4329614 StA Ctry Cd: USA Reg Cd: NA Repr Date:12-AUG-2004 Doc #:087540A
Cust Comments: CUSTOMER STATES THAT LEFT TURN SIGNAL WAS BLINKING MUCH FASTER THAN THE RIGHT SIDE BUT CUSTOMER NOW STATES THAT LEFT TURN SIGNAL IS INOP
Tech Comments: INSTALL BULB
1FTSW31P84ED60646 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-MAY-2004 08-JUL-2004 116515 USA 2 7D05 170104 4C3Z 15200 AA R10 D8 1850
AWS Claim Key: 1985856 Trx Code: 1 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 01362 - * Name: BOB RUTH FORD, INC. Ph: 717-4329614 StA Ctry Cd: USA Reg Cd: NA Repr Date:12-AUG-2004 Doc #:087540B
Cust Comments: CUSTOMER STATES THAT ONE OF THE FOG LIGHTS HAS WATER IN IT
Tech Comments: INSTALL FOG LAMP HAD TO REMOVE LICENSE PLATE HOLDER TO INSTALL
1FTSW31P84ED60646 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-MAY-2004 08-JUL-2004 116515 USA 4 2G05 031405 * RECAL * D36 42 3591
AWS Claim Key: 2479436 Trx Code: 1 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 01362 - * Name: BOB RUTH FORD, INC. Ph: 717-4329614 StA Ctry Cd: USA Reg Cd: NA Repr Date:28-OCT-2004 Doc #:089184A
Cust Comments: CUSTOMER STATES THAT HIS FUEL MILEAGE HAS DROPPED FROM 20MPG TO 11MPG ON THE HIGHWAY
Tech Comments: DOWNLOAD WITH LATEST CALIBRATION
1FTSW31P84ED60646 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-MAY-2004 08-JUL-2004 116515 USA 8 1H03 030008 3C3Z 9F452 AC D36 42 6015
AWS Claim Key: 3856955 Trx Code: 1 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 01362 - * Name: BOB RUTH FORD, INC. Ph: 717-4329614 StA Ctry Cd: USA Reg Cd: NA Repr Date:09-FEB-2005 Doc #:091541A
Cust Comments: CUSTOMER STATES THAT ENGINE HAS NO POWER AND BLACK SMOKE COMES OUT OF EXHAUST WHEN PRESSING ON ACCEL.
Tech Comments: INSTALL EGR VALVE
1FTSW31P84ED60646 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-MAY-2004 08-JUL-2004 116515 USA 11 1H03 030008 4C3Z 9F452 A D36 42 7856
AWS Claim Key: 5126590 Trx Code: 1 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 01362 - * Name: BOB RUTH FORD, INC. Ph: 717-4329614 StA Ctry Cd: USA Reg Cd: NA Repr Date:05-MAY-2005 Doc #:093538A
Cust Comments: CUSTOMER STATES THAT ENGINE LACKS POWER AND BLACK SMOKE COMES OUT OF EXHAUST
Tech Comments: INSTALL UPDATED EGR VAVLE AND UPDATE PROGRAM IN PCM
1FTSW31P84ED60646 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-MAY-2004 08-JUL-2004 116515 USA 11 3A03 * * * * * * 8288
AWS Claim Key: 5481896 Trx Code: 04B24 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 01362 - * Name: BOB RUTH FORD, INC. Ph: 717-4329614 StA Ctry Cd: USA Reg Cd: NA Repr Date:23-MAY-2005 Doc #:093961A
Cust Comments: RECALL 04B24 TRANS REVERSE PLANET
Tech Comments: PERFORM RECALL 04B24 PER FORD
1FTSW31P84ED60646 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-MAY-2004 08-JUL-2004 116515 USA 16 * * * * * * * 18210
AWS Claim Key: 7529046 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 01362 - * Name: BOB RUTH FORD, INC. Ph: 717-4329614 StA Ctry Cd: USA Reg Cd: NA Repr Date:28-OCT-2005 Doc #:097589A
Cust Comments: RECALL 05S34 FUEL INJECTOR CONTROL MODULE WIRING HARNESS
Tech Comments: PERFORMED RECALL 05S34 PER FORD
AWS Claim Key: 7529047 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 01362 - * Name: BOB RUTH FORD, INC. Ph: 717-4329614 StA Ctry Cd: USA Reg Cd: NA Repr Date:28-OCT-2005 Doc #:097589B
Cust Comments: RECALL 05E15 EXHAUST PRESSURE SENSOR
Tech Comments: PERFORMED RECALL 05E15 PER FORD
AWS Claim Key: 7529048 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01362 - * Name: BOB RUTH FORD, INC. Ph: 717-4329614 StA Ctry Cd: USA Reg Cd: NA Repr Date:28-OCT-2005 Doc #:097589C
Cust Comments: RECALL 59B01 ONE TIME TEST DRIVE
Tech Comments: PERFORMED RECALL 59B01 PER FORD
1FTSW31P84ED60646 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-MAY-2004 08-JUL-2004 116515 USA 16 2D02 030805 5C3Z 12224 A D36 42 18210
AWS Claim Key: 7542808 Trx Code: 05S34 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 01362 - * Name: BOB RUTH FORD, INC. Ph: 717-4329614 StA Ctry Cd: USA Reg Cd: NA Repr Date:28-OCT-2005 Doc #:097589D
Cust Comments: CUSTOMER STATES THAT ENGINE LACKS POWER AND BLACK SMOKE COMES FROM EXHAUST AT TIMES
Tech Comments: INSTALLED NEW CONNECTOR ICP CONNECTOR INSTALLED FOR RECALL 05S34 WAS BAD INSTALLED ANOTHER TO CORRECT CONCERN F
1FTSW31P84ED60646 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-MAY-2004 08-JUL-2004 116515 USA 22 5V01 050306 1C3Z 3B396 CB C50 42 20830
AWS Claim Key: 9209208 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 01362 - * Name: BOB RUTH FORD, INC. Ph: 717-4329614 StA Ctry Cd: USA Reg Cd: NA Repr Date:24-APR-2006 Doc #:101026A
Cust Comments: CUSTOMER STATES 4 WHEEL DRIVE HUBS HARD TO TURN
Tech Comments: CHECK FRONT HUBS AND CHECK FOR BINDING REPLACE HUBS AND AND RECHECK OPERATION
1FTSW31P84ED60646 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-MAY-2004 08-JUL-2004 116515 USA 22 6J14 0114XX 6L3Z 25218A43 AA L07 42 20830
AWS Claim Key: 9209209 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 01362 - * Name: BOB RUTH FORD, INC. Ph: 717-4329614 StA Ctry Cd: USA Reg Cd: NA Repr Date:24-APR-2006 Doc #:101026B
Cust Comments: CUSTOMER STATES DOOR LOCKS NOT WORKING
Tech Comments: CHECK DOOR OPERATION AND REMOVE DOOR PANELS AND CHECK FOR CURRENT AND GROUND REPLACDE BOTH DOOR ACTUATORS
1FTSW31P84ED60646 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-MAY-2004 08-JUL-2004 116515 USA 28 5V01 060301 * 1125 * N27 13 30598
AWS Claim Key: 10461220 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00053 - * Name: CHESAPEAKE FD TRK SLS INC Ph: 410-6824000 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:10-OCT-2006 Doc #:125874A
Cust Comments: STEERING WHEEL SHAKES ON BRAKE APPLICATION
Tech Comments: PERFORMED DIAGNOSTICS AND FOUND FRONT ROTORS WA RPED. CUT ROTORS AND TEST DROVE OK
1FTSW31P84ED60646 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-MAY-2004 08-JUL-2004 116515 USA 28 2H01 031202 5C3Z 6C640 AA D42 01 30598
AWS Claim Key: 10469873 Trx Code: E84 Labor Hrs: 6
Dlr Cd-Sub Cd: 00053 - * Name: CHESAPEAKE FD TRK SLS INC Ph: 410-6824000 St:MD Ctry Cd: USA Reg Cd: NA Repr Date:10-OCT-2006 Doc #:125874B
Cust Comments: LOSS OF POWER
Tech Comments: PERFORMED DIAGNOSTICS AND FOUND AIR TO AIR TUBE TORN. REMOVED AND REPLACED TESTED AFTER REPAIR OK
Old 03-16-2008, 01:39 PM
did i have more than one page lol??
Old 03-16-2008, 01:45 PM
Gun Nut
Yeah - every one I send has two files.
Old 03-16-2008, 01:51 PM
what program do i open the second one with ??
Old 03-16-2008, 06:30 PM
Served our Country
I didnt know it had two either
