08 Diff cover bolts - Ford Powerstroke Diesel Forum
Old 03-15-2008, 03:28 PM
Slacker
Feedback Score: 4 reviews
08 Diff cover bolts
As part of my 60k maintenance, I am getting ready to do an overhaul on my fluids. I already bought my 08 differential cover and now realize that I need some longer bolts... Any idea what the length of those bolts are? Or, better yet, what the part number is for them? I can't find them in the parts lookup... Thanks!
Old 03-15-2008, 03:41 PM
ADMIN AND TECH
you dont have to get them from ford , i just took my old ones out , went to the local hardware store and found the correct length i needed out of the bulk bolt section
YOUR STOCK ONES WILL WORK THEY ARE PLENTY LONG.
Old 03-15-2008, 03:44 PM
Slacker
That's kind of what I was thinking, Scott. Appreciate it!
Old 03-15-2008, 03:45 PM
ADMIN AND TECH
my stock ones wouldnt work
Old 03-15-2008, 06:19 PM
Have you actually installed an 08 aluminum cover? The original bolts are 3/8" too short. You can't even get a thread started with them. The bolts are 1/4" x 1-1/8" to 1-1/4". I used stainless steel socket head cap screws. They weren't cheap but added a slight bling factor to the install and insured no rust when it's time to change that oil again.
Old 03-15-2008, 06:24 PM
Slacker
Thanks, Matt. Did you get them from a hardware store or where did you get them?
Old 03-15-2008, 06:32 PM
Just about any hardware store with specialty bins will have them Shawn. I tried Home Depot first because they were the closest thing to me but they don't carry them. I actually even had trouble getting the right length at the hardware store. They only had like 4 of the 1-1/8" bolts. The rest I bought were 1-1/4 and 1-1/2" that I trimmed a little to fit.
It may even be easiest just to order them from McMaster-Carr, Grainger or somebody like that. My problem was I waited until I needed them to look them up.
Old 03-17-2008, 03:00 PM
yes and the stock ones worked for me
Old 03-17-2008, 03:13 PM
how much is the 08 diff cover?
