Boost Gauge Suggestions?
Okay, I am looking at getting a boost gauge and would like to go with a Autometer Sport Comp gauge. However, I am torn between two of them.
My question is this....does a diesel work under the same principal of a gas engine in terms of Vacuum? Would it benefit me to use the gauge that has the vacuum as well? OR would it be a waste? AND if I go with the non-vacuum gauge, will I have a problem exceeding 35 pounds of boost with nothing more than a Xtreme Street tune and full exhaust? I don't think so, just wanna be sure. |
Nope. No vacuum in a diesel; you'll be fine with a 35 psi boost gauge with stock turbo... Besides without studs, anything higher than that and you'll be needing HG's...
DITTO........
Doesn't your truck have one in the instrument cluster?
Yes, and a Trans Temp gauge too, but I aint trusting either.
The stock boost gauge isn't very accurate and the trans temp gauge is just an idiot light.
Good to know
