Is there a reliable 6.0??? - Ford Powerstroke Diesel Forum
post #1 of 21 Old 05-23-2013, 06:03 AM Thread Starter
Well here is my story: I race modifieds on the weekends, and tow our triler with my dodge cummins (please don't knock it I really love this truck), and the truck tows awesome, just not enough room for all our help. So, we tried finding an rv with a diesel..too expensive. So I then said, well ford makes the excursion. Now, I'm well aware the 7.3 seems to be a more reliable engine, however didn't ford change the 6.0 around 2005 and make a much more durable engine? Whatever we choose for a hauler will be towing a 28ft enclosed trailer weighing at 15-16k. We are trying to find an excursion with the 7.3 but everyone wants the moon for the dang things, so I was curious if I could expand my possibilities with a later 6.0 excursion. I don't want problems, my 5.9 cummins has been awesome for durability and towing power. If we cant find an excursion, I'll probably end up getting a 2006 mega cab..let me know guys thanks!
monster50iii is offline
post #2 of 21 Old 05-23-2013, 06:38 AM
IMHO no year of 6.0 is better than the next. All years need about the same "mods/fixes" to be reliable. I would blame alot of the bad reputation of the earlier models on inexperienced techs and mis-diagnosis.
2003 F-250 ECSB 4x4
4" MBRP turbo back
SCT
S&B cai
435 rwhp / 767 rwtq
13.94 @ 97 (with a terrible 60')
Jesse S is offline
post #3 of 21 Old 05-23-2013, 06:39 AM
Term3's Avatar
Quoted: 2 Post(s)
The 6.0 can be a very reliable motor. My '05 Excursion has had two things go wrong since I bought it new, a $25 relay and a FICM which was my fault as I knew my alternator was on its way out. I installed the Bullet Proof Diesel FICM upgrade which is made to military specs. I think the 7.3 is more popular then the 6.0 Excursion but if you take care of known 6.0 issues ahead of time you can have just as reliable of a vehicle as I do. IMO synthetic oil is a must. Like you've found out Excursions are in high demand and prices don't seem to go down. Every single time I stop off at a Ford dealer I barely get one foot on the ground getting out of mine before I get a salesman asking if I would be willing to sell it and even though I say no they always give me their card if I change my mind. They never try to sell me a new vehicle they just want my stock Excursion bad. LOL
Good Reading
Things to consider about owning a 6.0
Monitoring a 6.0
Bullet proofing the 6.0
Tech files
Side effect of disconnecting EGR valve
Tech Info
Powerstroke Books
Powerstroke Info
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #4 of 21 Old 05-23-2013, 06:43 AM
Bump To Pass!!
toren302's Avatar
Quoted: 1707 Post(s)
This is best explanation for the 6.0 engine.
toren302 is offline
post #5 of 21 Old 05-23-2013, 07:08 AM
Jack Lester's Avatar
Quoted: 3 Post(s)
From my experience so far if you by one delete the egr, upgrade stc fitting, coolant filter, elc coolant,blue spring upgrade, monitoring system...
Jack Lester is offline
post #6 of 21 Old 05-23-2013, 07:22 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
So basically after you spend all that money doing these things your better off getting the 7.3 excursion but good luck like you said everyone wants and arm leg and kidney for one
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #7 of 21 Old 05-23-2013, 07:40 AM
william_ace's Avatar
Quoted: 2 Post(s)
I don't believe that to be true. The 6.0 is a great motor, its just a different animal than the 7.3. If you don't do maintenance like you're supposed to, and neglect the truck, then yes, you're better off with a 7.3. If you want more power with a better transmission and you're willing to do the maintenance to it, then IMO the 6.0 is a great choice.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #8 of 21 Old 05-23-2013, 07:42 AM
goosegodz's Avatar
My 6.0 was almost completely stock... did the blue spring upgrade, religious oil/filter changes with rotella syn and swapped out my coolant for cat-1 rated...monitored it since almost day one and ran an sct tuner.... It was an 03 and only thing I had to do was change an injector....Ran great for almost 10 years.....
2013 F250 6.7 ccsb,Carli Pintop 4.5, FUEL Offroad Octane Rims, Toyo MT's 37, Smittybilt light Bar, Rigid D2's, Rigid 20" LED
goosegodz is offline
post #9 of 21 Old 05-23-2013, 07:43 AM
Chapter Director
Quoted: 5 Post(s)
Yea i mean i dont deny that it CANT be reliable but i just find it hard to spend 10k+ on a truck that still needs 5k+ to make it right
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #10 of 21 Old 05-23-2013, 09:01 AM
Quoted: 2 Post(s)
Really sound like a dodge guy, find an ex without a diesel and put a cummins in it. Lots of guys have supposedly done the conversion and cummins are supposed to be cheap to find for wrecks etc. I know you said you dont want to spend the 5K to do what is needed, but there are many 6.0 out there without problems or that have already been fixed/bulletproofed. When you buy used you are actually buying a pig in a poke no matter the brand. I would be fearful of buying a dodge that has been modified because they then per different articles Ive read they tend to have some of the same issues many complain about the fords having. Yes some will run but you got to know who did what and why to them also.
So if you find one, find someone who knows about them and have it checked out, may run$100 or so but in the long run could be well worth it.
HankY is offline
