Will these fit?
Hey guys. I am going to put a 6" lift on my 2006 f-250 cc. I am planning on keeping the stock 20" wheels and running 37x13.50x20's. Will i have any rubbing problems keeping the stock wheels? Thanks in advance
their gonna stick out a lot from the sides... and yes its prob gonna rub...
+1 on the rub and I think they may be to wide for the stock wheels...
I'm with rednekexprez it might rub but those tires are too wide for the stock rims. They will not wear correctly and may be unsafe.
I think the 37's will fit on the stock 20's. The nitto mud grappler (just an example) rim width recommendation is 8.5-11" I know the 20x8 rims are just outside of that but they should be fine not including rubbing.
Im debating between the nitto mud grappler and the toyo mt's. Do yall think that if i ran 37x12.50x20's i would be alright on the rubbing and rim issues?
![]() ![]() the toyo will cost more then your truck though
I went with the mud grapplers for my 1st set after the stockers and unless you plan on mudding a lot I don't recommend them. I loved them at 1st since they are so aggresive looking and had a mean howl but the vibration and noise became too much on the road after a while. I hear great things about the Toyo's though.
37x12.5x20 will fit on a leveled 05-07 SD with stock wheels.
