Egr delete and fan function - Ford Powerstroke Diesel Forum
post #1 of 38 Old 05-14-2013, 04:06 PM Thread Starter
Jack Lester's Avatar
Quoted: 3 Post(s)
Since I deleted my egr and don't have the pigtail plugged in does this mean my fan will not work at all? Second question when the engine gets hot enough to go into de-fuel mode is it very noticeable or not (an extreme loss of power)?
Jack Lester is offline
post #2 of 38 Old 05-14-2013, 04:19 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
It will work, it will just be at a reduced speed. I've been trying to find the thread that explains it but haven't had any luck yet.
dhanna6powerstroke is offline
post #3 of 38 Old 05-14-2013, 05:14 PM
5fifty's Avatar
I deleted my egr and left it plugged in. I bolted it up out of the way on an in used hole right above the area where it used to be. Larz at Gearhead recommend it before I got my tunes to help with the fan, and cooling. It dropped the temps around 5-10 degrees at highway speeds on my truck.
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #4 of 38 Old 05-14-2013, 05:47 PM
RetiredFD's Avatar
Is there a difference with my EGR cooler blocked off, and my EGR valve still in place? I keep getting the CEL, just waiting to get the tuner to change that. Is that going to change my fan control, or just when I get the tuner?.
- Chris
2006 F250 CCSB Lariat
RetiredFD is offline
post #5 of 38 Old 05-14-2013, 05:50 PM
Mod Newbie
Quoted: 19 Post(s)
As long as the valve is present and plugged in, the fan will work fine. You need to leave it plugged in even with the tuner and having the system shut off.
post #6 of 38 Old 05-14-2013, 06:17 PM
RetiredFD's Avatar
Thanks. I guess that is my answer then.
- Chris
post #7 of 38 Old 05-14-2013, 09:10 PM Thread Starter
Quoted: 3 Post(s)
@dhanna6. Can I just plug in a old egr from any truck I don't have mine? Can I just leave it plugged in on top of the engine in a safe place?
post #8 of 38 Old 05-14-2013, 09:14 PM
Mod Newbie
Quoted: 19 Post(s)
That should work fine.
post #9 of 38 Old 05-14-2013, 09:18 PM Thread Starter
Quoted: 3 Post(s)
@dhanna6. Do you have any experience with our kind of trucks going into de-fuel mode? Is it very noticeable when this happens due to high temps?
post #10 of 38 Old 05-14-2013, 09:20 PM
Mod Newbie
Quoted: 19 Post(s)
I have personally never gotten one that hot. I've had them refuel based on my EGT settings but I'm sure that is different.
