new fuel filter - Ford Powerstroke Diesel Forum
Old 03-01-2008, 02:17 PM
new fuel filter
what a pain in the a** the bottom one to get to is there a better way i use the 36mm sotck and the crossment in the way and dirver shaft to. sorry if this is a dumb ??
Old 03-01-2008, 02:33 PM
Rice Hunter
they are a pain in the azz especially when the aluminum gets rounded out. They make a
hand turn model with a "T" that keeps it from falling to the ground when draining. Ford has them for about $20.
Old 03-01-2008, 05:24 PM
thanks you i will check it out
Old 03-01-2008, 05:25 PM
I went at bought a 36Mm and used my ratchet. I did not have much trouble getting it off. There was not a lot of room, but I made a lot of small turns. But putting it back on was a pain. The threads would not line up for nothing. I tried for 30 minutes to get it to thread on. Would not work. I just changed the oil and got to looking at the oil filter cap. Same one. So I took off the oil cap, slip in the fuel filter and it screwed on by hand. I took the one that was on the fuel filter and put it on the oil filter. For some reason, I guess it was the angle on the fuel filter, it would not screw on. Plastic threads going into metal ones can be harry.
Old 03-01-2008, 05:35 PM
i here there i think i iam going to get a long ext it mite work. guy who put it toghter was one of the look good on paper guy.
