fuel system upgrade
Howdy guys lookin for the simplest and best upgrade for the fuel system not lookin for 11 sec truck just upgrade do i need just a better lift pump or a return sys and just how hard is the return sys. to install saw a write up put dont remember sayin how hard it was
dj's fuel + intensifier seems to be a good upgrade for a "stock" truck, definitely for stock injectors. I'll hopefully be doing mine in about a month. ::: DJ's Perfromance :: Home :::
A full RR install is not very difficult but is very challenging because of the lack of space that you need to work in. The fuel intensifier is a "helper" pump to ensure that you don't starve your injectors for fuel under heavy acceleration conditions.
Hey Shawn,
The FUEL+ Fuel Intensifier is a regulated return fuel system. It will work with up to 250cc injectors. It will take you between 1 - 2 hours to install. It is not a helper pump, there is no pump involved. It consists of fuel lines, an Aeromotive regulator, fuel pressure gauge and all the fixings for an easy installation. You do not need to go to the back of the heads to get the best results at all. DJ |
originally posted by Evil Eye
Perhaps a FASS or AirDog was on your mind...also a good addition. Stay Tuned Amp |
these sound great guess i better wait for the warranty to run out first but def. on the to do list after 100k man that list is turnin to a book
ITP 6.0 fuel system with the airdog would be a great choice and you can't beat the service.
a fuel system should have nothing to do with warranty. it provides constant fuel, which is good for the injectors.
