NEED HELP w/ a 2005 flasher relay replacment - Ford Powerstroke Diesel Forum
Old 02-29-2008, 09:43 AM
Exclamation NEED HELP w/ a 2005 flasher relay replacment
I need help locating the flasher relay on a 2005 F-250. It says nothing about it in the owners manual so any help will be greatly appreciated.! Thanks in advance
Old 02-29-2008, 12:25 PM
If you are talking about your hazards, it is called a multi funtion switch. It runs turn signals, brake lights, high and low beams. I fought with the same problem and it is a simple easy fix. the handle that you use for the turn signals and every thing else needs replaced. All you have to do is unbolt the top of the steering colum and there if I remember right 2 more bolts that hold the switch together. Unpug it and ford will have the repacemnt. I spent 2 weeks trying to figure out what was wrong and it took only 10mins to fix.
If this is what is wrong I hope this helped if not disregard everything I have said.
Old 02-29-2008, 12:56 PM
i figured it'd be a relay bad, so what i gather from you is that there isn't a relay its all in the multi function switch/flasher etc. lever and no relay to go out. Thanks for the input
Old 02-29-2008, 01:10 PM
I did the same thing. I chased relays and fuses, and even tested all of the wiring from the lights to the cab. Then some one here goes, there is no relay just the multi switch. I went then fixed it.
Old 02-29-2008, 02:04 PM
thanks, its still under warranty so ill try that ill call the dealer in the am and try to get it taken care of thanks, i would have chased fuses and relay until summer trying to fix it.
Old 02-29-2008, 06:12 PM
No problem. Glad I could help keep you from like I did.
Old 05-31-2009, 10:05 AM
i've been having the same problem, just wondering if installing the new switch fixed it for you?
thanks,
travis
