Tell me about diesel exhaust fumes - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-27-2008, 06:24 AM Thread Starter
Question Tell me about diesel exhaust fumes
I've been searching for a year or so for a good used PSD. Finally found one that fits us and fits the budget. Took SWMBO out for an hour test drive. She likes it, she really likes it!!
Went to pick it up last night and sign the paperwork. The dealer had it running for 20 minutes or so while we exchanged cash for keys. When we drove away there was a faint (to me) odor of diesel exhaust in the cab. In my mind it's what drifted inside while we were getting in. I'm 99.99% sure there's no exhaust leakage based on the previous hour we spent with no problems.
SWMBO is very sensitive to fumes of any type and is now worried that we may have a major problem. What has been your experience in normal day to day operation? Do diesel fumes get into the cab in your experience? Is there any accepted method of measuring the cab atmosphere?
Your wisdom is being sought!
Jim
2004 F-350 Lariat X-Cab PSD FX4 longbed
(newbie to the diesel world)
Maineiacs is offline
post #2 of 4 Old 02-27-2008, 06:57 AM
assistant director
thbd77's Avatar
no havent had no problems
Name-Troy Lincoln
96 F-250 4X4 stroked xcab shortbed 5 speed
01 EXCURSION LIMITED 4X4 V-10 brute force intake dual exhaust
02 EXCURSION LIMITED 4X4 stroked ts 6 position 4" dp and duals hers now
06 F-250 4x4 6.0 auto lariat crew cab short bed Dads ride
thbd77 is offline
post #3 of 4 Old 02-27-2008, 07:04 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
SWMBO ??
LOL.
No you should not be smelling fumes while driving, but while parked and idling, yes, you will sometimes.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #4 of 4 Old 02-27-2008, 07:22 AM
Is it even worth it???
ABOBB's Avatar
First of all....
Welcome to Powerstroke.org
Unless you can smell exhaust while driving, I'd say that what you experienced was fumes that drifted into the cab of the truck while you were getting in.
If this persists, or you begin to notice the smell even while driving, you should either check, or have someone check, your exhaust system.
You did not specify exactly what year truck, but I do know that the 6.0 engines sometimes have issues with up-pipes, and egr plumbing that allows exhaust to escape under the hood, which is then picked up by the cab ventilation system.
ABOBB
Aaron A. Bobb
2002 F-250 SD ExCab, Short Bed, PSD, Auto trans, 4X4
Custom tuned 6 position Chip
Whelen CSP690 Strobe Kit (Installed @ Feb Indy Strokers Rally... Thanks Adam), ZooDad Mod
COMING ATTRACTIONS:
Heated Side Mirrors, Owner Built Rear Airbag System
Owner Built Front Bumper, Owner Built Tymar Intake
Owner Built Custom Exhaust, Rear Roll Pan?
ABOBB is offline
