best oil - Ford Powerstroke Diesel Forum
post #1 of 37 Old 02-25-2008, 04:32 PM Thread Starter
billbigrig's Avatar
best oil
what ansoil is the best for my 05
:mike
o5 F250 xlt 4x4 cc short box
4in exhaust turbo back no kitty but a muf.
airaid intake ,edge juice with attittude
96 zrt 600
05 f7
06 road king
R I P
the beast 86 f350 460 and a 4 speed
:burnout
billbigrig is offline
post #2 of 37 Old 02-25-2008, 04:56 PM
Locatoraaron's Avatar
10w30...... do not use 15 40 in a 6.0 ltr... it will blow your turbo and cause injector problems.
Locatoraaron is offline
post #3 of 37 Old 02-25-2008, 05:11 PM
ssdeuce's Avatar
didnt think they made a diesel 10w30 oil thought it was 15w40 or 5w40 syntheic
I MAY BE CRAZY BUT I AIN'T DUMB
04 F250 6.0 FX4 CC SB
S&B intake
CFM+ INTAKE ELBOW
4" TURBO BACK STRIAGHT PIPE NO CAT
SCT W/ VIVS TUNES
ZOODAD MOD
SUPERCHIPS DUAL LAZER GAUGE (EGT&BOOST)
ford blue spring
banjo bolts
and heck its my slowest vehicle
gotta work on that
ssdeuce is offline
post #4 of 37 Old 02-25-2008, 05:11 PM
DryHeatDude03's Avatar
Can't say I exactly agree with this. I've run 15w-40 for years without incident. To each his own I guess.
-Chris-
2003 F250 SC/LB 6.0L 4X4
DryHeatDude03 is offline
post #5 of 37 Old 02-25-2008, 05:25 PM
Beatngu's Avatar
It gets cold in WI right? lol, Id go with 5w/40, good on cold start ups and holds thickness when hot.
2016 AG GT350
2013 Fresh150
2008 F350 Lariat Stroker
2005 F250 Lariat Stroker
2004 Mach1 6 spd Black on black
DSS 5.0L stroker
Comp cams w/ FRPP ported heads
twin Turbonetics
13psi 749 hp / 620 ft. lbs. @ 16*
E85 numbers to follow
old Kenne Belle setup at 16 psi
and so on......
600 hp / 585 ft. lbs.
Beatngu is offline
post #6 of 37 Old 02-26-2008, 04:59 AM Thread Starter
billbigrig's Avatar
thanks i ll go with 5w/40
:mike
96 zrt 600
05 f7
06 road king
R I P
:burnout
post #7 of 37 Old 02-26-2008, 05:08 AM
consult the people at ford. It really depends on where you live and what you use your truck for. right? Hot weather, lots of towing ya for sure 5 40. my truck really runs best at 10 30. i just ran the 5 40 for the last 2 changes and it was ok but better with the 10 30..... that being said i do run my truck all day everyday, in the Canadian cold and watch every mpg closely and listen to my engine. my wife calls me nuts but it runs better and starts easier.
Ams oil is the way to go. if you can add the fass system. i want one for my next addition to my 6.0 psd
post #8 of 37 Old 02-26-2008, 01:29 PM
Don't use 15-40? that is the one which my manual recommends; '07
If you go Amsoil don't forget to join the preferred customer program makes the stuff very attractively priced.
robert smith is offline
post #9 of 37 Old 02-26-2008, 01:55 PM
i use the 5w-40 in my 2006 !!!
pete37922 is offline
post #10 of 37 Old 02-26-2008, 07:11 PM
Have you guys ever heard of "motor kote" ?
