Transmission Filter for the 5R110 TorqShift? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 09-15-2006, 08:44 AM Thread Starter
Hi Guys,
A Newbee here.... Wondering if here are any "Main" trany filters available for the 5R110 Trany other than the Dealer? Tried a search here and did not find any info about it. Just bought a used 2003 F250 and have been going over items and changing the filters and fluids. The only one that I have not been able to track down is the new style filter located inside the trany pan. It is different than the E40D style.
This is our first Diesel Truck and enjoying it very much.
Is this a Dealer item only?
Thanks in advance!
Jim G.
Arkmx is offline
post #2 of 13 Old 09-15-2006, 09:43 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
First of all welcome to the forum!
On your tranny filter question, on the 03 models, that filter is one part that may not be avaiable yet at other stores. Dealer item only. I'm not saying that is for sure the case but i know i have gone to the local parts store for certain items on my 03 and they told me it was too new a model for them to carry that part. I think it was the alternator i was shopping for and only Ford had it. I ended up going to a rebuild shop and they took care of it. Call your local parts house and they either have it, or they don't.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #3 of 13 Old 09-15-2006, 01:02 PM
Glenn M's Avatar
http://www.dieselsite.com/index.asp?...S&Category=420
http://www.suncoastconverters.com/fo...10filters.html
Glenn
The only time it ends, is when your pockets are totally empty!
2001 4x4 F-250 SD,SC,SB, Lariat, PSD, HX cross over, DT466 cps, Ford AIS intake, 4" Pinnacle pipe, built trans, Dacco 3disk converter, Isspro pillar gages. MAP reg., ZooDad Mod,TS 6-pos chip,Truxedo/Plus Tonneau.
Glenn M is offline
post #4 of 13 Old 09-15-2006, 05:25 PM
keep in mind your tranny has two filters, one internal (in the pan) and one external on the passanger framerail right in front of the motor....its is an aluminum canister with a 7/8 head on it for removal...
mschn99 is offline
post #5 of 13 Old 09-18-2006, 05:27 AM Thread Starter
Thanks Glenn, that's what I was looking for!
Marc, Thanks for the heads up on that one. I was able to find a replacement filter for that one, easy to change out too.
Thanks again!
Jim.
Arkmx.
Jim G.
Thanks to Zach & Trace's 2008 Sponsors!
Kawasaki Sports Center, Lucas Oil, Engine Ice, Factory Connection, Pro Clean, Answer, Pro Taper, Gaerne, Factory Effex, Scott, Kenda, EVS, EVOmx, MX Resultz.com & JTG Racing.
Arkmx is offline
post #6 of 13 Old 11-15-2006, 04:00 PM
quickwrench's Avatar
Thanks again!
Jim.
Hello, guys. New to the site...
Jim, what Mfg/Part were you able to use for the spin-on filter element? I can't seem to find one readily available [except the Motorcraft filter]. When I do a X-ref for Fram/Purolator [for the Motorcraft 3C3Z7B155BA], they show an internal filter.
quickwrench is offline
post #7 of 13 Old 11-16-2006, 06:39 AM Thread Starter
Quickwrench..... The part number is the one you have (3C3Z7B155BA) and it is an internal filter type, like the oil & fuel filters. (Sun Coast, around $15 plus shipping.)
Also the filter inside the trany pan is new.... part #3C3Z7A098AA (@ $21)
Hope this helps!
Arkmx.
Jim G.
Arkmx is offline
post #8 of 13 Old 12-11-2006, 06:19 AM
dustindiesel's Avatar
just an update..i found that napa sells the spin on filter with a new gasket for 22 bucks and change..also the internal pan filter as well but i dunno the price
2003 psd 6.0
red crewcab
16" suspension lift, 48" michelin xml's on 20x10 black rockstars, 6000k hid's, crossover steering, zoodad mod, ccv mod, modified up pipe to delete egr cooler,high idle mod, mbrp 3.5 downpipe, train horns(also on remote), diamond plate tool box, recon smoked cablights, Code670 alarm/remote start,100w reverse lights, oil-based underbody paint
**soon to purchase SCT rockwell 2.5 ton frt/rear
-8,520lbs with me in it
dustindiesel is offline
post #9 of 13 Old 04-10-2007, 01:03 PM
IggyAZ's Avatar
Smile Transmission filter
Hi Guys,
Thanks in advance!
Jim G.
OPPPS I see I didn't read all the msgs. Someone already told you about the ext filter.
I just had my transmission oil changed and the filter in the transmission is just cleaned and not replaced. Also do you know you have an external treansmission filter under the passengers front wheel well? It is like a roll of toilet paper and gets changed every 30,000 miles. Just thought you'd like to know,
Iggy
2003 Powerstroke 6L
8ft bed CC
Arizona Gold
SURPRISE ARIZONA
IggyAZ is offline
post #10 of 13 Old 04-10-2007, 03:36 PM
An update, since this thread has been revived anyway.
As a biz owner whose crews service a ton of PowerStrokes, we've located a great source for both the internal [pan] and external [framerail] filters for 6.0L-equipped E- and F-Series Fords.
Frankly, I'm kind of disappointed in most of the online sources for these [and other items]. It would be no problem for us to put these out for $15 [internal] and $20 [external] SHIPPED, but we're really not in that business.
Thanks for the help, guys.
Sean Sparacio
