Ford Powerstroke Diesel Forum
Ford Powerstroke Diesel Forum (http://www.powerstroke.org/forum/)
-   General 6.0L Discussion (http://www.powerstroke.org/forum/general-6-0l-discussion/)
-   -   what are signs of clogged egr cooler (http://www.powerstroke.org/forum/general-6-0l-discussion/383658-what-signs-clogged-egr-cooler.html)
6.0 excursion 04-03-2013 04:44 PM
I have a 2005 6.0 powerstroke excursion 208000 miles cat delete changed egr valve thin coating of soot it was a little greasey .origanal egr cooler sometimes runs rough loses power getting p0404 code what are the signs of clogged egr cooler .was reflashed in 2010
Snake 04-03-2013 05:18 PM
EGR coolers rupture when they fail, not clog. If your EGR valve or the inside of your intake is wet, then the EGR cooler has probably gone 10 toes up.
6.0 excursion 04-03-2013 05:40 PM
thanks ,ya i am going bulletproof .why is it running rough sometimes and what is code p0404 mean?valve and intake were not bone dry but a little gooey no coolant lose no smoke or steam at exhaust
HarvestingInternationally 04-04-2013 06:43 AM
Run your truck hard after it warms up...park it with the nose facing down...like on a hill...wait about 8 hours and pull the egr valve out n see if it's wet...I had the same issue and turns out my cooler was shot...when I pulled it outta my truck it was full of coolant
6.0 excursion 04-04-2013 10:31 AM
Will a bad egr cooler make the truck run rough sometimes and lose power?
Snake 04-04-2013 11:03 AM
It can, yes. Any smoke out of the exhaust? Usually it's most noticeable on a cold start.
6.0 excursion 04-04-2013 11:56 AM
This may sound weird,when you turn the key to on position and hold the trip button on instrument cluster till it says test then start the truck.You can scroll through to digital rpm ,my truck always fluxgates 10-15 rpms .Just making example but we will say it's at 650 it will go 658-667-648-660 never constant.And does anybody know what the other things are in the cluster,there's rpm,alt volts ,dtc .I would love to know what all these readings are.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
