O6 F250 center carrier bearing..... - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-20-2013, 07:56 AM Thread Starter
bassn5150's Avatar
How much slop should the carrier bearing have? At about 50 mph and beyond, I have a vibration. You can't feel it until you hit 50-55 mph. Its definitely coming from the rear. It's not shaking the truck apart, but noticeable. I can grab hold of the drive shaft right at the bearing carrier and move it an 1/8 of an inch or slightly more. The truck has 170k on it. Just trying to get an idea. Thanks in advance!
bassn5150 is offline
post #2 of 8 Old 03-20-2013, 09:09 AM
husky74's Avatar
Have u checked all the u-joints, also what is the condition of your tires?
as for carrier bearing that movment should be ok.
07 F250SD Lariat 6.0
ARP head studs
Updated factory head gaskets
BD diesel egr cooler delete kit
New factory oil cooler
New updated factory turbo
Fuel pressure upgrade
New Ford Injectors
CCV Mod
Banks high-ram kit
Airaid air intake
Zoodad Mod
SCT X4-SRL+, Edge Monitor
Coolant filter
4" turbo back exhaust
08 trans pan + filter
08 Mirrors
08 Rear Diff cover
Rear Air Bags
husky74 is offline
post #3 of 8 Old 03-20-2013, 09:12 AM Thread Starter
bassn5150's Avatar
U joints are good. The tires are probably 60% worn. I'm gonna get them rebalanced. Start with the simpest solution, work toward the hardest!
post #4 of 8 Old 03-20-2013, 09:48 AM
F250SixOH's Avatar
I had a driveline shop pull my two piece drive shaft last fall. The U-joints and carrier bearing were good but both shafts were out of balance. Truck feels a lot better now. I'm still fighting tire balancing issues though
F250SixOH is offline
post #5 of 8 Old 03-20-2013, 09:49 AM
pcris's Avatar
Are you lifted or stock height?
06 F250 CCSB FX4
SCT SF3
ELC | T6
CTS | EGT
EGR Delete
High Idle
Blue Spring | FP Gauge
PMM Coolant Filter
Leveled|35's
LED Reverse|Bed Rails
08 Trans Pan/Filter
4" Straight Pipe
-Philip
pcris is offline
post #6 of 8 Old 03-20-2013, 09:50 AM
F250SixOH's Avatar
Mine is stock height.
post #7 of 8 Old 03-20-2013, 10:07 AM
pcris's Avatar
I meant the OP in regards to his issue.
06 F250 CCSB FX4
SCT SF3
ELC | T6
CTS | EGT
EGR Delete
High Idle
PMM Coolant Filter
Leveled|35's
08 Trans Pan/Filter
4" Straight Pipe
-Philip
pcris is offline
post #8 of 8 Old 03-20-2013, 10:24 AM Thread Starter
bassn5150's Avatar
Stock height. Factory 20's.
