Scangauge II - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-13-2013, 04:00 PM Thread Starter
Jack Lester's Avatar
Quoted: 3 Post(s)
Scangauge II
I just got a scangauge II what are the most important things I want to monitor? Please put in terms I can understand I'm new to all of this thanks.
Jack Lester is offline
post #2 of 10 Old 03-13-2013, 04:36 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
ICP
IPR
EOT
ECT
FICM Main 48v
Bat V
Trans temp
Others as required:
MAP Boost
EBP
PW
Inj Timing
VGT %
If you get additional gauges:
EGT
Fuel Pressure
Boost
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 10 Old 03-13-2013, 04:39 PM
Chanzfx4's Avatar
Feedback Score: 3 reviews
The scangaugeII will monitor all that?
2003 White F350 Fx4 CC SWR
Go Fasts:
X2 tuned with SRL+
4 Inch Open Dp
Egr Delete
Blue Spring Mod
Riff Raff Boots
Sinister Coolant Filter
All Aluminum Radiator
ZooDad
Looks:
Blacked Tails
285/75/16 Destination M/Ts
Camo Interior
Leveled
Raised Black Nerf Bars
Black Bed Rails
Chanzfx4 is offline
post #4 of 10 Old 03-13-2013, 04:40 PM Thread Starter
Quoted: 3 Post(s)
I know it sounds dumb but what is icp and ipr
post #5 of 10 Old 03-13-2013, 04:43 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 898 Post(s)
Feedback Score: 6 reviews
Yes and more, you just have to program to read what you want.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #6 of 10 Old 03-13-2013, 04:44 PM
RIP Cam!
Quoted: 898 Post(s)
I should clear that up a little... it will monitor all that, but can only disply 4 things at a time.
post #7 of 10 Old 03-13-2013, 04:51 PM
RIP Cam!
Quoted: 898 Post(s)
Here's the link to the programming info.... Ford Specific XGauges : Linear Logic : Home of the ScanGauge
post #8 of 10 Old 03-13-2013, 04:56 PM
RIP Cam!
Quoted: 898 Post(s)
ICP = Injector Control Pressure (sensor)
IPR = Injector Pressure Regulator (valve)
post #9 of 10 Old 03-13-2013, 05:02 PM Thread Starter
Quoted: 3 Post(s)
Thanks rattlesnake. What kind of numbers am I looking for on the icp and ipr as well as ficm numbers? Thanks for your time and patients.
post #10 of 10 Old 03-13-2013, 05:49 PM
RIP Cam!
Quoted: 898 Post(s)
No problem bud, we are all here to learn and help each other out. Check out these links and I bet you will find all the info you need.
IPR vs ICP ???
Lets talk ICP and DC%
As far as FICM voltage, you want to see between 48v and 47v, assuming you have a stock 48v FICM. if it dips below 47v I would do a physical voltage check KOEO, cranking, and running.
