What causes the P0299 code - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-10-2013, 09:37 AM Thread Starter
Fox Hunt's Avatar
Quoted: 23 Post(s)
So since I've installed my hybrid turbo and my S&B intake at the same, I'll check my codes once and a while and I get the P0299 code- Turbocharger under boost. I've read maybe unison ring, but I'm sure Adrian would have had that in good shape already, I've also read aftermarket intakes and boost leaks can cause this, but it builds boost fine. Anyone have any helpful insight?
Sent from AutoGuide.com App
2006 F-350 CCSB Lariat
MBRP 4" Exhaust, ARPs, Barder Stage 2 turbo, S&B CAI, TSD SPD, Warren Competition transmission, Edge CTS, Coolant Filter, High Idle Mod, CCV Mod, Zoodad, Newton Leveling kit, Fuel Mavericks 20x9 , Pioneer DVD head-unit, JL Stealthbox and JL Slash 500/1v2 amp
Future Mods:
Injectors and Driven Diesel RR
-Alex
Fox Hunt is offline
post #2 of 5 Old 03-10-2013, 09:56 AM
Quoted: 43 Post(s)
I get the same code too. Only when pulling a trailer though. Plowing i don't get the code.
gtmustang00 is offline
post #3 of 5 Old 03-10-2013, 02:50 PM
nordstrom's Avatar
Quoted: 2 Post(s)
Yes unison ring and/or sticking vanes can cause this along with intake leaks and egr related things. Never really heard of a CAI causing an under boost. Other famous cause's are the EBP sensor and a sticky VGT solenoid
2006 F350, Holders Ported Intake, ARP Studs, Factory Turbo w/MTW Billet Wheel, Edge Insight, Atlas 40 FICM Tune, Stock Sticks, BPD Ficm 53V, BPD EGR Cooler, BPD Remote Oil Cooler W/ cold weather pkg, BPD Water Pump, Blue Spring Upgrade, S&B Cold Air Intake, CCV Relocate, 64K miles and counting
nordstrom is offline
post #4 of 5 Old 03-10-2013, 03:15 PM Thread Starter
Fox Hunt's Avatar
Quoted: 23 Post(s)
Re: What causes the P0299 code
EBP sensor should be clear, checked it a few thousand miles ago and it was clean then. Only happens occasionally, I'll leo a closer eye on it
Future Mods:
-Alex
Fox Hunt is offline
post #5 of 5 Old 03-10-2013, 04:09 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
On a stock turbo 90% of the times this is caused by a sticking or stuck turbo. If your peak boost is low all the time it can be an intake or exhaust leak
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
