OASIS report cause for concern? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-08-2008, 03:12 PM Thread Starter
I bought a 2005 F250 a few weeks ago and just received the following OASIS report. Sadly it's only for the past year. I'm not sure what I'm looking at, so if anyone can give me some feedback I'd appreciate it.
Thanks
OASIS RESULT:
1FTSW21P75EA16558
01/04/2008
22:09:54
FCXWS447
Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
37 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
ATTENTION TECHNICIANS AND SERVICE MANAGERS:
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 07-21-05
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/31/2004 BUILD DATE
08/17/2004 SALE MILEAGE
00012
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
01/02/2007
DEALER: Tenvoorde Ford, Inc.
WARRANTY CLAIM NUMBER: 275269 ODOMETER: 084905M
PART NUMBER PART DESCRIPTION QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001 6005F 42 DOES NOT OPERATE PROPERLY
5C3Z 9A332A HOSE ASY (FUEL HIGH 001 6005F13
95874S101 002 6005F2
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 004 6005F14
000 6005F18
000 6005F8
000 6005F6
000 6005F22
000 9527AT
000 062203A
000 MT9527AR
000 OSL
84000 VERIFY CONCERN ENGINE CRANK NO START PERFORM PRELIMINARY INSPECT OIL LEVEL OK. FUEL OK. FUEL PRESSURE 50 PSI OK. PERFORM PINPOINT TEST P CHECK ICP PRESSURE WITH SCAN TOOL 30 PSI IPR 84%. PERFORM EEC TEST P0272-CYLINDER CONTRIBUTION-BALANCE CYL #4 P0284-CYL # 8 CONT BALANCE REMOVE LEFT BANK V ALVE COVER AND INSTALL HIGH PRESSURE OIL RAIL AIR PRESSURE TEST BEFORE
01/02/2007
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 8005D 42 DOES NOT OPERATE PROPERLY
3C3Z 6766BA CAP ASY OIL FILLER 001 9456A
4C3Z 9P456AF COOLER - EGR 001 12650D30
F6TZ 9160AA GSKT- FUEL FLTR BOWL 002 MT062514
W301558 001
3C3Z 6A831AA GSKT-OIL FLTR ELEM S 001
VC 7B 003
3C3Z 6840AA GASKET-OIL FILLER AD 001
84000 PERFORM COOLING SYSTEM PRESSURE TEST FOUND NO EXTERNAL LEAKS REMOVE E GR VALVE AND INSPECT INTAKE FOUND EVIDENCE OF COOLANT. REC. REPLACE EGR CO OLER AND EGR VALVE. REC. HAVE INTAKE CLEANED. 3 AS PER TSB 6-25-14. DRAIN C OOLANT AND REMOVE RAD FAN SHROUD AND FAN ASSEMBLY. REMOVE FICM REMOVE TURB O REMOVE OIL FILTER AND SECONDARY FUEL HOUSEING. REMOVE INTAKE REMOVE AND RE
Click Here for Full Warranty History
| On-line 1878
END OF OASIS REPORT FOR 1FTSW21P75EA16558
Mustang1989 is offline
post #2 of 6 Old 01-08-2008, 03:21 PM
Don't mind me
westcoaststrokin's Avatar
Quoted: 3 Post(s)
I have an example of what an OASIS shouldn't look like if you want me to email it to you I will. That doesn't look to bad to me but I am in no way a tech.
Josh
04 F350 CC SB DRW IT HAS SOME STUFF
"Idiopathic, from the Latin meaning we're idiots cause we can't figure out what's causing it." House M.D.
westcoaststrokin is offline
post #3 of 6 Old 01-08-2008, 05:45 PM
goodriddance's Avatar
not sure why they didn't get you the full report, looks like EGR and EGR cooler problems, pretty common, should be fine now, maybe couple injectors, I'm not a tech sure why will chime in and set me straight
goodriddance is offline
post #4 of 6 Old 01-30-2008, 03:49 PM Thread Starter
The trucks in the shop right now having all the fluids changed to Amsoil. While its there I asked them to check out the antifreeze leaking from the top of the radiator. (see the picture) Could this be the EGR acting up again? Is there anything specific or anything else at all I should have them look at?
post #5 of 6 Old 01-30-2008, 03:51 PM
strokerboy73's Avatar
could you send this to me please? bgboxberger@digis.net
-2003 7.3L Powerstr
ke, 4x4, Crew Cab, 170K Miles
"The Last Of A Dying Breed."
-Banks 6 Gun -Straight Piped
-Zoodad Mod -DIY Intake -CCV Mod
-B&W Turnover Ball -Prodigy Brake Contoller
Future Mods:
-4 into 5 in. Turbo Back Exhaust. 6 in. Tip
-Custom Front Bumper
strokerboy73 is offline
post #6 of 6 Old 01-30-2008, 03:52 PM
Desert Shield/Storm Vet
vitalidle's Avatar
It there was not warrenty work done in 05 or 06 it won't show up on the report. Only when it was brought in for warrenty work will it show on the report
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
