axles and info on them - Ford Powerstroke Diesel Forum
Old 01-07-2008, 02:42 PM
i was wondering where i can find out what the front axle is and the rear and whats in them
Matt
Old 01-07-2008, 02:43 PM
International Threat
Your front is a Dana 60, and rear is a Sterling 10.5". Should have 3.73's.
You can look on the rear diff tag and it will tell you for sure.
Old 01-07-2008, 02:44 PM
If it aint a CAT itsa DOG
yep check the rear diff tag. Mine says 3L73, meaning 3.73 limited slip
Old 01-07-2008, 02:46 PM
yea 3.73 but i think i heard that they put dana 44 axle in a dana 60 and call it a 50 is this true well when in 4 wheel it is really jerky almost like the front is a posi so i want to check that out
Matt
Old 01-07-2008, 03:04 PM
i thought the dana 50 was the old ifs junk on the OBS 250's. Maybe i'm wrong.
Old 01-07-2008, 03:11 PM
Yours is definately a Dana 60.
Old 01-07-2008, 03:28 PM
thanks
Matt
Old 01-07-2008, 03:58 PM
Dana 60 front only came on models with dual rear wheels. Single rear wheels are Dana 50 its the same cover as the 60 but with a little smaller ring gear.
Old 01-07-2008, 08:25 PM
This should help some guys out...Automotive What is my Ford rear end ratio, do I have positraction
Old 01-08-2008, 06:24 AM
Yep dana 60 housing with dana 50 guts duallys and heavyduty 350s got 60s
