Help - Small Leak
Hello all,
I noticed that I have a small leak on my 05 F250. The leak appears to be above the oil pan where the tranny and engine meet. I'm not very mechanically inclined so I was hoping someone here might be able to give me some advice as to what it might be before I take it to the dealer. It's a very small leak as I don't see any fluids hit the ground unless it's sitting over a period of a couple days. Also, are leaks covered by the 100K powertrain warranty? Thanks for your time and help! |
The 6.0 is 2 piece block, if thats where it looks like thats the leak than I would take it to a dealer and at least make a note of it.
It has a silicone rope seal between the 2 halfs, it may not be nothing major right now but could get worse. |
i have noticed the same leak on my 2005 truck also.. i just havnt had time to take it to the dealer yet
Yes, that is where the leak appears to be coming from. Would that be covered under warranty? If not, is it an expensive fix? |
crappy to hear, i think i have the same leak......probably a cup to cup and a half of oil over 2 weeks......stained the hell outta my new driveway. SUCKS
Bump...
Would this be covered under warranty? If not, is it an expensive fix? |
It's most likely the short hose between the oil cooler and EGR cooler. Climb on top of the engine and reach under the turbo stand and see if you can feel some wetness around that hose. It leaks under the turbo and down the back of the block. Very common problem. About a 35 dollar hose and about two hours of labor by yourself.
I'll check that out tonight. By chance would that be covered by the powertrain warranty? |
Also check you oil filter on top of your motor mine started leaking for no reason and it leaked down the valley and off the back. When I got under the truck it was leaking off the oil pan and the bell housing. I quess the o ring went bad. So changed oil new o ring everythings a ok
I guess I should have asked this from the start, are you leaking coolant, crankcase oil, grape jelly, what????????????
