Why are diesels so noisy when cold? - Ford Powerstroke Diesel Forum
post #1 of 41 Old 01-02-2008, 08:25 PM Thread Starter
I know this is probably a dumb question for all you guys that have had diesels for years, but this is my first winter with one.
I was just curious why they're so noisy and rough running when cold.
Should I go to a different grade oil? I just changed it with 15/40 2k ago, so I'd hate to waste 40 bucks worth of oil if I don't need to. It runs in the 20s most of the time where I live in the winter with occasional dips to single digits.
2006 F-250 Powerstroke Crew Cab Lariat Long Bed 4x4 FX4
SCT Xcal2 with Xtreme tunes by Innovative
Banks Monster Exhaust/Quadzilla Commander
ARP Head Studs and Elite Sneaky Pipe (Thanks Scuffy)
tech10002 is offline
post #2 of 41 Old 01-02-2008, 08:31 PM
KVFD
redstroker_2002's Avatar
ur oil is fine its just the diesels! they run like that make sure to have additive in fuel and allow plenty of time for warm up!
-Josh
2008 2500 LMM- Deleted, Blocked, Fueled, & Tuned by:
redstroker_2002 is offline
post #3 of 41 Old 01-02-2008, 08:36 PM
diesels only really need two things to fire....
Fuel
and Heat.....
Compression produces the heat with air.....
Injectors provide the fuel....
Now cold air makes it tougher for the air to get warm enough to ignite the fuel...even with the glow plugs. Topp that off with the oil being extra thick since it is what makes the injectors push the fuel into the cylender.....the combined two things make them run a little "off" when they are cold....
Just provide a little extra warm up time and know the nature of the beast...its nothing to worry about!!!
mschn99 is offline
post #4 of 41 Old 01-02-2008, 08:37 PM Thread Starter
Yeah, I did notice that it runs a LOT better when I plug the block heater in overnight. I'm visiting my dad in Houston now, and even here with the 30 degrees it is now, it's really noisy when I start it.
Does anyone know technically why they run noisy when cold? I'm just curious as to what process actually causes it internally.
post #5 of 41 Old 01-02-2008, 08:39 PM
KVFD
everything just has more stress when its cold. its hard to move all the fluids around when they are thicker because of the cold. thats about the best i can sum it all up!
-Josh
post #6 of 41 Old 01-02-2008, 08:41 PM
the noise is the injectors. Its called injector "knock"....
What happens is when the injector is functioning...the oil pressure is magnified through a intensifier piston....
When that happens...thats the louder knock that 7.3's and 6.0's have over common rail motors like the d-maxes and newer cummins motors. That noise is greatly amplified when the oil and fuel are cold since the injector, fuel pump, oil pump, etc have to work a little harder to get everything there. The combination of it all produces that knock you hear...
mschn99 is offline
post #7 of 41 Old 01-02-2008, 08:44 PM
KVFD
dam mark u know ur business!! lol.. i think u should for what u do for a living
-Josh
post #8 of 41 Old 01-02-2008, 09:27 PM
hvyw8's Avatar
Cycle your glow plugs 2-3 times. It has been in the teens the past week or so here and plugging it in at night and cycling the glow plugs makes it fire right up without being too rough.
HVYW8
2004 F350 Crew Cab 6.0
6" lift
Toyo Open Country 35's with 18" rims
Xcal3 tuned by Innovative running Xtreme daily
Boost, Trans, EGT pillar guages
4" turbo back straight pipe
Zoodad
Airaid intake
hvyw8 is offline
post #9 of 41 Old 01-03-2008, 07:19 PM Thread Starter
So that's why I wake up the neighbors in the morning. LOL
So what is an intensifier piston? Are they called that because they take oil at less than 3000 PSI and inject fuel at up to 20k PSI?
I think I have a pretty good idea how this HEUI system works, but I don't really understand the concept of the intensifier piston. Here's my take... The low pressure engine oil pump provides pressure to pump oil to the HPOP reservoir. The HPOP then sends high pressure oil up to about 2700 PSI to runners in the heads that then lead to the injectors. That pressure is controlled by the IPR, which is electrically controlled by the ECU. Inside the injector, some kind of electromagnetic solenoid valve(Maybe a pilot operated pintle valve???)directs the high pressure oil to the top side of a piston in the injector which forces the fuel into the engine at much higher pressures. The fuel enters the bottom side of the piston through a separate low pressure fuel rail.
Am I even close to how these things work? I'm just guessing on most of this, as I can't find a good theory of operation writeup on the internet.
I'd really like to see a diagram of these injectors. I'm curious how the oil returns back to the engine after firing the injector and also how the valving works in the injector on both the engine and fuel side--like does it just use passages covered by the piston as it moves, like a 2 cycle engine...
Educate me.
post #10 of 41 Old 01-04-2008, 03:28 PM
Unapologetically American
2006PSDSD's Avatar
Quoted: 29 Post(s)
Feedback Score: 4 reviews
The 6.0 is suppose to run 10w/30 heavy duty diesel oil. I run Rotella right now. If I plug my truck in, I have no starting issues even in below zero temps.
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
