Will 8x170 fit an 05 sd ??? - Ford Powerstroke Diesel Forum
Old 01-01-2008, 02:33 PM
I have the opportunity to buy a set of rims off of an 02, will the pattern work with my 05 ?
Old 01-01-2008, 02:58 PM
Send a message via AIM to eazenutz33
yup......my rims and tires were on a 2000 if I remember right....whatever truck WhiteLongBed has on here.
Old 01-01-2008, 02:59 PM
+1 more for they will fit....
Old 01-01-2008, 03:14 PM
The pattern is the same back to 99. Before 99 was the 8 on 6.5". Make sure they are at least 17" rims also. 04 and earlier had a smaller front caliper that would allow you to use 16" rims. 16" rims may not clear your calipers.
Old 01-01-2008, 03:41 PM
thanks guys, they are 22's so they should be ok. now im just worried about the backspacing and being able to clear them with my lift
