A couple of questions about the EGR cooler - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-28-2007, 04:20 PM Thread Starter
Resident Tire Smoker
raveer2000's Avatar
I made a post in the problems area about the cold start problems I have been having.. The responses that I got were that I need to take it to have the latest flash done that had some kind of update with cold weather. The service writer told me that he had heard of no such flash before.(Scary) Anyway, the service writer told me that from my symptoms he would guess that it is the EGR cooler and they would have to tear into the motor.. So I made an appointment with them as I bought the truck there and they did a great job doing the bed plate seal on the truck. He said the mechanic was already gone for the day and that he would mention it to him on Monday. One question is do they have to pull the heads to get to the EGR cooler. I ask because then I will have studs put in at the same time. Is this a good time to have them put in studs? I am also getting a weird howling noise from about 13 PSI and up of boost. It is not a turbo whine or whistle. Maybe a leaking IC tube?
Looking to buy again
raveer2000 is offline
post #2 of 6 Old 12-28-2007, 11:25 PM
Slacker
Evil Eye's Avatar
Quoted: 190 Post(s)
Feedback Score: 4 reviews
They won't pull your heads for the EGR cooler replacement. I would certainly check out your CAC tubes for your howling as you've already suggested.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #3 of 6 Old 12-28-2007, 11:49 PM
eazenutz33's Avatar
Send a message via AIM to eazenutz33
mmmmkay.....whats IC tube or CAC tube????
I may have to start my own thread, but whenever I let off the throttle when its colder, even if the trucks warmed up, it lets off a lil howl. I dont run my truck real hard, so we're talking 1/2 throttle or so and barely letting off. Not a whine like the turbo when ur boost is high, but slightly lower pitched and maybe 2-3 seconds long at the most. Didnt notice it until the temps started dropping below 40 or so.....they haven't gotten back up yet so I cant compare to warmer temps. I do know the blue tube coming out of the turbo looks like it has leaked oil with dirt stuck to it all over it, not enough to think its a running leak, but like someone misted it with WD40 and the dirt stuck if that makes sense.
It may be normal and I'm getting vehicular paranoia from seeing others problems.
2005
F250 4x4 CC/SB
-un-important stuff...lifted, 20's, 37's, exhaust, SCT, gauges, AFE, ZooDad, horns, tint, dvd, AV, speakers,...
-IMPORTANT stuff....1yr. old Peyten riding along with me in the back seat and his pregnant mommy in the passenger seat......due May 2010!!!
eazenutz33 is offline
post #4 of 6 Old 12-29-2007, 09:03 PM
Slacker
Evil Eye's Avatar
Quoted: 190 Post(s)
The blue tubes that you describe are your intercooler (IC) or cold air charge (CAC) boots. You should check those carefully as they can develop a tear, but they are tough considering what they are designed to do. The oil accumulation is normal for your IC boots.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #5 of 6 Old 12-29-2007, 10:19 PM
eazenutz33's Avatar
normal is my favorite word for tonight! haha
2005
F250 4x4 CC/SB
post #6 of 6 Old 12-30-2007, 11:41 AM
razorbackfan's Avatar
I saw on my Oasis Report where they replaced my EGR cooler and had 11.2 hours on there. I don't know if that was the only thing but if it was that's like $700 in labor charges.
razorbackfan is offline
