Installed 35x12.50 Procomps
got it done yesterday. 35x12.50R20 load range E. Xtreme AT's. so far... I've noticed they are VERY Quiet. I can't tell the difference between them and my OEM tires; only been up to 60mph so far. They are small though... they measure 33.5" if you measure them on the truck. 4wheel parts installed them with 55psi. I aired them up to 65psi like the door tag calls for. Used some white out, and made a line across the treads. drove around for a while... wow, the edges were not even touched! so I aired them down to 55psi and that was very good for the fronts. the rear still were wearing in the center, so I aired them down to 50psi. That seemed to be the best combo I've tried so far.. 55psi front, 50psi rear. Didn't want to go under 50 w/out posting and asking what you guys are running for air pressure? I'm running the factory 20's.
i have had 3 sets of the procomp extreme ATs on my two trucks and i will continue to buy them. they are in my opinion the best tires i have owned so far. and i have an 06 with the 20 inch wheels and i also put the 35s on and they dont rub a bit
unloaded 50 psi is fine... mine wear MUCH better in that range then at the recommended 65...
just remember to air them up if you tow...
do you have any pics i am looking for the same combo?
how do i make a post or "thread"? a lil help please anyone
Pics are coming tomorrow. I had to wash my truck this afternoon, was filthy. Yeah, if I tow I'll air them up. On the rear it could almost be deflated another 5psi.. making it 45. How does F-50psi/R-45psi sound? is that to low? I'm debating trying it just to see the wear pattern compare to the 55/50 I'm at currently.
One other note. I left my mud flaps on the front, they don't rub! Kind of sad, but I don't even need the 4" lift to run these. They don't rub the radius arms at all, 1-2" clear. And they don't even come remotely close to the front bumper valance. I'm guessing it's b/c the tires only measure 33.5", and i'm on the factory wheels.. Last edited by JBakerFX4; 12-23-2007 at 03:01 PM. |
on my truck I had to run the front i had to run 65 psi so I could keep the truck on the road it road like crap with 50 in them, and i also have 65 in the rear tires. I have yet to take some paint and go over the tire tread, hopefully i will get to it soon.
I drove around all yesterday with 55psi in F&R and it drove great.
man when i had my tires installed they had 50 psi in them the truck was all over the road at like 50 mph, I could not believe it, it was really scary thats when i played with the presure.
