Maximum safe EGT and Trans temp towing - Ford Powerstroke Diesel Forum
post #1 of 33 Old 12-21-2007, 03:57 PM Thread Starter
I'm getting ready to go on a trip where I'll be towing a 7000-8000 pound trailer 1000 miles each direction, and a good bit of that will be through mountains.
When I'm going through the mountains, what EGT/trans temps should I run at continuously before backing off? I have my EGT warning set at 1250 now, but I have no clue what to set the trans warning at.
2006 F-250 Powerstroke Crew Cab Lariat Long Bed 4x4 FX4
SCT Xcal2 with Xtreme tunes by Innovative
Banks Monster Exhaust/Quadzilla Commander
ARP Head Studs and Elite Sneaky Pipe (Thanks Scuffy)
tech10002 is offline
post #2 of 33 Old 12-21-2007, 04:06 PM
Raul@Stealth Automotive's Avatar
1250 is a good level.. you can go a lil higher but not for a long period of time... as far as trans i wouldnt want you to go over 200... anything about 210 and youll be burning oil....
Raul@Stealth Automotive is offline
post #3 of 33 Old 12-21-2007, 04:06 PM
Turnin' JP8 into noise!
duck's Avatar
You won't have any problems. I took a 11000lb+ trailer through Wyoming (7000-9000ft the whole bottom half of the state) and never saw much over 1100. You might get up into the 12-1300 range if you're really getting on it, but not likely. Trans never saw over 175 deg.
06 F350 Harley Edition
Crew Cab Long Box
Auto Meter Ultra-Lite Gauges
MBRP T304 SS 4" Turbo Back
AFE Stage II intake
Zoodad
Fluidampr
B&W Turnover Gooseneck Hitch
Xtang Revolution Tonneau Cover
Line-X w/ removable Carpet Bed Kit
2.5" Leveling Kit
BFG A/T KO 285/65/20R
Recon Smoked Cab and Tail Lights
If you ain't CAV, you ain't sh&#!!!
duck is offline
post #4 of 33 Old 12-21-2007, 06:02 PM
WD40's Avatar
Quoted: 35 Post(s)
Good people on here telling you the truth. 1250 and 200 max on Trains.
Have a super safe trip, and a Merry Christmas.
2006 Ford F-350 Crew Cab Lariat 4X2 PSD 6.0 TorqShift Automatic Transmission. Upfitter Switchers Chrome Door Handles,
Oxford White with lower part being Arizona Beige Metallic.
Creative Coating Sprayed in bed liner.
20K Reese 5th wheel hitch.
Mods. 4in. Silverline stainless steel exhaust
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
Is it time to go camping?
EX-USN
Doug
WD40 is offline
post #5 of 33 Old 12-21-2007, 11:59 PM
you can run hotter than 1250 on the egt's and if you have a tuner and a trailer, you will definitely get to that temp in a hurry. 6.0 very tolerant of EGT, you can run 1350 without worrying about anything, i've run 1400* for extended periods and never done any damage at all...
mercon SP is synthetic fluid, there is no reason you need to worry about temp unless you have some sort of mechanical failure. the most you will likely see is around 160*, i've seen some get up to 175* on a HOT day pulling a big grade, and your tranny fluid will handle well over 200*, remember these arent the trannies of yesterday that would burn up at 210, you can run 250, but there is no way i see it getting that hot if everything is operating correctly.
LvTitan is offline
post #6 of 33 Old 12-22-2007, 09:18 AM
WD40's Avatar
Quoted: 35 Post(s)
Sorry LvTitan, but I will have to disagree with you on taking the 6.0 up to 1400. If you ran it at 1400* for a extended period of time you didn't do it any good.
I will stand by what I said about the 1250 and the 200 EGT/trans temps.
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
EX-USN
Doug
WD40 is offline
post #7 of 33 Old 12-22-2007, 09:22 AM
Abrannan19's Avatar
Feedback Score: 5 reviews
^^ i agree..I hit 1600* all the time..but I wont say I am not doing any damage somewhere.
Adam Brannan
First Coast Diesel Performance
Abrannan19 is offline
post #8 of 33 Old 12-22-2007, 09:45 AM
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Feedback Score: 4 reviews
At those temps, I'm sure your rings are screaming! I would agree keep it around 1250 and you could bump it a bit higher than 200 on the tranny, but you likely won't see that in the winter time unless something isn't working properly.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #9 of 33 Old 12-22-2007, 10:16 AM
Desert Shield/Storm Vet
vitalidle's Avatar
One thing to keep in mind is those are safe limits you can probobly run all day the 1250 and 200 but anything higher your longevity is thrown out the window. I would absolutely crap my pants if my gauge ever got to 250 for trans temp! lol. To each there own but to be safe keep or try to keep it 1250 and 200
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #10 of 33 Old 12-22-2007, 04:12 PM Thread Starter
Thanks for the info.
Now I'm a little bit worried about my trans temps. Unloaded, they run around 145-150. I picked up the flatbed today. With just the empty trailer, my trans temps were touching 175 in stop and go traffic in town. Is that normal? I'd guess the trailer weighs about 2000-2500 empty.
How long can I run higher than 1250 without hurting anything? There are some pretty steep grades I'll be pulling, so I'm sure I'll hit 1250 a few times along the way.
