some maintenance info - Ford Powerstroke Diesel Forum
Old 12-20-2007, 06:05 AM
Question some maintenance info
When reading the manual, it says to lube chassis and other misc. parts. does anyone know if there is a diagram that shows all the points that should be checked? Also what grease to be using in all locations? Is it all the same or some different than others?
just wanting to geet the best life out of my truck without taking it to the stealership!!
thank you!!!
Old 12-20-2007, 01:31 PM
Old 12-20-2007, 01:45 PM
Desert Shield/Storm Vet
There really isn't many places to lube on stock parts. If you had greasable ujoints and ball joints I would say hit them with the gun, but you don't. Not sure of any, but someone will chime in if there is
Old 12-20-2007, 01:55 PM
only ones i know of are on the tie rod ends and the drag link
that's on my 02 not sure on your 07
Old 12-20-2007, 02:17 PM
On my 06 I have grease fittings on the Ft. universal joints also.
Old 12-21-2007, 08:05 AM
any type of grease? what weight are you using or just a typical bearing and chassis lube?
thank you for the help!!!
