You will need the eas universal sensor input and a 100psi sender. You can use any 0-5v sender, I ended up using the edge pressure sensor. Got them both off amazon.
Sensor will go in place of the test plug on the front of the fuel bowl. You will also need a m12x1.5 oring to 1/8" adapter. I put a 1/8" 90* after the adapter for a little bit more clearance. Strictly Diesel has a kit to relocate the sender with a hose.
I didn't use the a relocate kit because it is temporary, I am getting ready to build my own fuel system and R R.
I agree with the too pricey portion of adding fuel psi. As much as I like my CTS, it is a bit more costly to have everything monitored in one spot. Having said that, I have the expandable egt which isnt a bad price, but after seeing I need two parts for fuel, adding up to almost $300, I have been thinking about a steering column gauge just for fuel and the rest on my cts. This way its still a somewhat clean install, I get to keep my oh sh!t handle, and its slightly cheaper.
I'm struggling with how to do a fuel pressure gauge with my current setup. I could get the single pod that mounts below the OMG handle, but I'd have to move my Banks IQ and its awesome where it is.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
