Will they fit?
I found a great deal on a set of 35X14X20 swamper iroxs. A lady has them for $200 and I need a set of tires bad. Seeing as the stock tires are 34.1 inches tall, won't these tires be okay. I know they will probably rub a bit on the radius arms under full turn but I can deal with that.
I'd say the width is probably going to be a problem.
I would also say that they will be to wide to not run when the truck is stock. and i dont beleive they will fit on your stock wheels, they might but you should have a 10 or a 12" wide wheel to be safe
They won't fit, you will need a wider rim, plus backspacing to clear everything behind the tire. The stock rims would have them sticking to far in the wheel well. Your going to rub more then just full turn.
NO THEY WILL NOT WORK
i dont think it would work very welll..
Well thanks for all the replies but I bought them today and put them on and they fit great. I believe the rim size narrowed the tire down so it only touches the radius arm in the last 5 degrees of steering turn.. So basically it barely touches the radius arm. Now I wouldn't go rockcrawling with it but for driving it on the road it is nice.
Lets see some pics.
Moon |
Sorry about the poor quality.
Those tires look really good. Makes the truck look bad azz!! Glad it worked out for ya!!
