Well the new BPD Remote Oil Cooler Kit showed up today that I will be installing on my buddy's truck when we do his head gaskets and studs here soon. We will get a build thread put together as he wants to get it studded and deleted and a mild build on it while it's apart. I'll link that thread here when we get started.
For now here is what everyone has been waiting for!!
That is correct. It retains the OEM oil filter housing and I am pretty sure it retains the OEM oil cooler upper housing (not the entire oil cooler housing just the upper part and the oil filter housing).
I would assume with the stock filter and upper housing still being used this kit would be a bit cheaper than the one with the remote filter. But then again you know what happens when you assume something.
Yes for cold climates there is a cold weather thermostat so to speak (again I don't know the specifics quite yet) I didn't have too long to evaluate the kit as I had to leave for work shortly after the package showed up, but there was definitely a thermostat in the kit as well. I will try to get some other pics of it tomorrow possibly.
The last time I spoke with Ken, which was too long ago, he indicated that this kit would be less expensive than the one they currently sell.
And yes, the cold weather kit is still recommended / required for those of you who don't have the common sense to move to a warmer climate. :funny: Although this kit doesn't use a canister style filter, it's still an air to liquid heat exchanger and subject to the same variables as the original.
Interesting kit here, I would like to see how everything fits together.
Between this kit using the stock oil filters, and BPD researching a more effective cooler for the lower geared/heavier trucks - this is becoming a very viable option for my build again.
Testing is complete and the HD coolers are in stock. We haven't listed them for sale to the general public or as an option yet as we still finalizing the bill of materials, pricing and ensuring backward compatibility.
I might have to talk to Ken about this. I noticed that they moved the 90* fitting for the oil cooler hose from the back of the transfer block to the top. Mine leaks very slowly, but I can't replace it without pulling the intake and EGR cooler out. I think that the o-ring may have twisted when I put it together the first time; tried to tighten it, to no avail :dunno:.
^ still waiting on fedex to bring this guys beta kit.
From what I can tell from the instructions it still uses the same cold weather manifold as the full kit. I'm not sure if they sent me the cold weather option though because I live in the south.
And as mentioned before I was told the target retail price will be 1,495 for the base kit w/o cold weather pakage.
Actually Nick the cold weather packs are in fact different between the two kits. The one for my kit (original BPD kit) is a thermostat that mounts to the oil cooler itself. This one has what looks like an "H" for the cold weather thermostat and has 4 lines running to it, 2 from the distribution block and 2 from the condenser mounted oil cooler. I do believe however that they still operate on the same principal though.
my kit still retained the factory oil filter canister, but it is now non-functional. never understood this. why didnt they retain it and still use an external filter? seems double filtration would be a good thing.
Well for oem the filter bypass is in the filter housing, one of the bennifits of the full bpd kit is it uses a new bypass system. The oem housing is retained because the fuel filter is on the same mount.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
