My truck has a Banks 4" single exhaust, with the cat and muffler. I'd like to be able to hear the turbo more but I don't really want a loud exhaust note.
I just install teh pure diesel power cat delete pipe. Easy to install. I love teh sound. I already had deleted teh muffler before. Its not realy loud unless u get on it and even then it sounds good.
Agreed, I have a 4" turbo back with no cat and muffler delete pipe. The turbo is loud! The exhaust note itself isn't really loud or obnoxious until you mash the go pedal or load it up with a heavy trailer.
just run straight pipe. im running 4in from where the cat was removed all the way to the rear. sounds awesome wide open and isnt loud at all on the highway or cruising.
Just called Banks, they don't offer a delete pipe...grrr. The way its designed though, I think I simply just need to get my tape measure out and go get a certain length of 3.5" pipe.
The part of the cat that has the flange on it is cut off 7" from the flange, 4" from the cat. Looks like it should just be a straight piece. Hey, I may come out cheaper than I thought!
I just did this a couple weeks back. I have the banks monster turbo back that uses the factory cat. Couldn't find alot of info online. Got under her looked at it and saw the 4" down pipe to 3.5" cat back to 4" banks. Had some creative juices and got some ideas. So I went to my local exhaust shop and picked up 20 inches of 3.5 inch pipe and used the clamps that it came with. Worked like a champ.
Ask the guy if he's got any scrap 3.5". Picked mine up for 5 bucks worth a shot lol. Overall I think you will like it. The turbo is a bit louder but overall not any louder than it was.
I ended up with a piece of ford pipe that had a bracket cut off so it gave me a place to whack it with my BMFH. It may give you some grief but brute force and awkwardness always prevail.
I did use some pb blaster to help expedite the process. Also you may want to make some marks on the pipe so you know where the ends are inside the other pipe.
Well guys I went to my exhaust guy to pick up the pipe, and of course his tune changed about removing the car when I got there. He's in the process of cutting out the entire 3.5" restricted area and is going to weld in a 4" piece. All for $85...yippee ha
Alright its all done, the turbo whistle is more pronounced for sure, not a whole lot though. EGT's idling when fully warmed up are about 15-20* cooler.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
