Torque shift ? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 12-07-2007, 01:46 PM Thread Starter
cgnav's Avatar
Torque shift ?
What do you fella's think a max temp for the Torque shift should be?
cgnav is offline
post #2 of 12 Old 12-07-2007, 01:47 PM
im fat and ugly
stump0331's Avatar
210 max, thats high
welcome to the site
2004 Excursion
stump0331 is offline
post #3 of 12 Old 12-07-2007, 03:23 PM
i've heard 220 personally. remember you have a fully synthetic setup so temp is not as critical as on older trannies... but you should never see it get that hot if everything is running prpperly. i have friends with tranny gauges and they say they usually run around 150-160 max even on hot days and when towing.
LvTitan is offline
post #4 of 12 Old 12-07-2007, 03:41 PM
im fat and ugly
stump0331's Avatar
yeah i have an additional tranny cooler and i never see 170 ever
2004 Excursion
post #5 of 12 Old 12-07-2007, 03:55 PM
Echo's Avatar
Ive never seen mine get over 160. Most of the time it's at about 145.
Echo is offline
post #6 of 12 Old 12-08-2007, 01:25 AM
stump how's it running ???
LvTitan is offline
post #7 of 12 Old 12-08-2007, 01:29 AM
im fat and ugly
stump0331's Avatar
pm me yur # lv
2004 Excursion
post #8 of 12 Old 12-08-2007, 02:29 AM
npccpartsman's Avatar
Quoted: 5 Post(s)
According to a Ford 5R110 engineer who worked on and helped designed the transmission, 230* is not a problem for this transmission. Most of the guys here that stated 145-170 are right on the money about normal operating temps though.
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
post #9 of 12 Old 12-08-2007, 03:25 AM
Towing heavy loads (25,000 lbs total vehicle weight) in 90 degree temps, I have not seen much more than 190 degrees. Like others have said avg running temp is 145 to 160 depending on outside temperature. I personally intend to keep mine under 210 and prefer to be under 200 for extended periods.
720Deere is offline
post #10 of 12 Old 12-08-2007, 10:56 PM
Originally Posted by stump0331 View Post
pm me yur # lv
done dirk diggler
LvTitan is offline
