egr removal, how to?? - Ford Powerstroke Diesel Forum
Old 12-05-2007, 05:20 PM
whats the best way to get rid of the egr?
block off?? then what with the rest of it? Cooler etc?
any other changes neccessary? computer issues, due to removal??
dont know why, i think i want to lose the egr.
if this is a dumb idea, also let me know..
__________________
Old 12-06-2007, 05:23 AM
Slacker
Feedback Score: 4 reviews
You can get an SCT with custom tunes and have your tuner remove the EGR from the programming. What I did (and what you might do) is block off the EGR cooler. For an 03-04, you can put a freeze plug in the intake side of the EGR cooler or for an 05-07 truck, you can buy a sneaky pipe from Elite diesel.
Old 12-06-2007, 05:45 AM
I don't mean to but I have a question along the same lines. If I install a sneaky pipe (to use my SCT), will I need to reinstall the stock pipe to prevent codes when "stock" and returning to the dealer?
Old 12-06-2007, 07:09 AM
i heard about the sneaky pipe, what exactly is it? for what years, i know egr on 03 04 is different from newer ones. reading threads i was thinking i understood, but their are different years, mines an 07
thanks
Old 12-06-2007, 11:15 AM
Slacker
Bush_Master, I think the answer is no, but we'll need a tech to chime in to be sure. In the latest reflash, I believe they remove the Exhaust Back Pressure reading, which is what I think was used to determine the EGR wasn't functioning properly.
Melmount, Its an up-pipe with the scoop removed and it will include a block off plate to prevent exhaust gas from entering the EGR cooler. The 03's and 04's didn't have a scoop in the up-pipe, but the 05's - 07's did. (Some 05's are actually 04 builds so may not have a scoop). LINK
