When you change your oil,does it matter if you take the oil filter out first than take the plug out? Or drain plug than filter. I usually unscrew filter than take drain plug out. Just wondering if it matters :dunno:
Agree, open up the oil filter lid so the oil drains down. I've always used the synthetic media filters from Amsoil and now have their bypass system installed. Oil looks almost new after a year of use when I change it.
And a thumbs up on the Amsoil stuff. I recently added a bypass oil filter with the Amsoil 2 micron, and I am impressed. Oil stays clean, no black soot in it.
I have always changed my oil as you guys described. Unscrew oil filter housing than go under truck and take out drain plug. But if you take out drain plug than unscrew filter housing,wouldn't the oil from the housing still drain down and out? Again I'm just wondering why it's done in a certain order...
ya it would still drain down and out of you take the plug out then take the filter out or loosen it if you leave the drain plug out. im pretty sure every one is assuming when you take the plug out you wait till it stops draining then put it back in. so if you take it out wait till its done draining and put it back in, then go to the top and do the filter your going to have a quart or whatever the filter housing holds stuck in the pan and not drained out.
oooh! lol. Your right macdougall. Yes, what I was trying to say if you take out plug before you unscrew filter housing "leaving the drain plug out" it would still drain out. Thx guys
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
