Batteries. - Ford Powerstroke Diesel Forum
Old 01-26-2013, 07:02 AM
Batteries.
I'm monitoring my voltage through my CTS. My volts when I KOEO are 11.5. After if fires up, they jump to ~13.7. I can run for however long and whe. I shut the truck off, the batteries are back down to 11.5. My thinking tells me the batteries are bad, and not holding a charge. The alternator is ok, or it wouldn't put up 13.7 when I'm running. But, I'm far from an expert on this system. Sound right to you guys?
Sent from AutoGuide.com App
Old 01-26-2013, 07:04 AM
NOT a Democrat
Your gauges are telling you what to do. I would just put a volt meter on them and double check. But more than likley they are bad.
Get some new ones! I nice set of 850CCAs!
Old 01-26-2013, 07:08 AM
Batteries.
Yeah. I'm going to the parts store in a few and have them tested out. I've about rebuilt this truck after I bought it! But, it should last me a long time.
Old 01-26-2013, 07:42 AM
if your near any truck dealerships you should try pricing batteries there. the local parts places here wanted $100-150 per battery for 850CCA. i got two 1000CCA batteries from the local international dealership for $100 a piece. there a little taller, but didnt have any contact with anything. warranty was the same or better then some parts stores also. with higher CCA and less $$.
Old 01-26-2013, 07:46 AM
Batteries.
Good idea too. Thanks
Old 01-26-2013, 08:59 AM
Batteries.
I had them tested and they were fine. Putting out over 13v. I guess the CTS isn't seeing it correctly in the KOEO position.
Old 01-26-2013, 09:05 AM
Re: Batteries.
Did they isolate the batteries when they load tested them? I don't trust the results.
Sent from my DROID X2 using AutoGuide.Com Free App
Old 01-26-2013, 09:09 AM
i went thru this a year ago i found out that the cts is showing a lower reading what i was told to do is put a volt meter at the batteries and i got almost a volt higher then what the cts said it was. my cts said 11.3 but when i put a volt meter at the batteries it was 11.9 and when it was charging the cts said 12.9 but the volt meter said 13.4. I used two different volt meter for this
Old 01-26-2013, 10:47 AM
Batteries.
Yes they isolated my batteries. My wife's uncle runs an autozone and I trust him. After I fire it up sometimes it'll read high 11s for a little bit, then instantly shoot to 13+. I'm thinking the CTS is having an issue with this one.
Old 01-26-2013, 10:58 AM
Re: Batteries.
Maybe, have you updated your CTS? The low voltage then jumping to 13 + is glow plugs continuing to draw then shutting down. I can see my headlights get brighter when my voltage jumps.
