Leveling The Exhaust - Ford Powerstroke Diesel Forum
Old 11-24-2007, 03:48 PM
I put a level to my tip and it needs to come up about a 1/4in....Should i just take it somewhere and have them do it or is there a easy way? Thanks..
Old 11-24-2007, 03:57 PM
Why do you want it level?
Old 11-24-2007, 04:00 PM
just figured it would look better level...
Old 11-24-2007, 04:06 PM
I see. We usually leave them pointing down slightly, and if the tip doesn't have a hole in it, we drill a small hole for condensation to run out of. When you firt start your truck in the morning and all that condensation comes out...thats were most of the soot on your truck comes from. There is no right way or wrong way...its your prefferance.
Old 11-24-2007, 04:08 PM
Loosen the clamp on the tailpipe section and tap on the pipe where it goes over the axle with a rubber mallet until your tailpipe is where you want it.
Old 11-24-2007, 04:12 PM
does the silverline tip have the small hole in the bottom...i might just leave it pointing down a little bit if thats how they all are....
Old 11-24-2007, 04:17 PM
Like Pat said leaving the tip pointing down slightly will let the condensation out on startups.
Old 11-24-2007, 04:33 PM
I'm not sure Casey. We carry about 8 differant brands. I think the Silverline does.
Old 11-24-2007, 05:26 PM
ok thanks pat...
