do I need to change gears with bigger tires - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-23-2007, 07:26 PM Thread Starter
java black's Avatar
Can I keep the stock gears on my 04 f250 with 35's ? At my local dealer the service tech mentioned I may want to put 4.56 gears in so the tranny does not work as hard.
java black is offline
post #2 of 12 Old 11-23-2007, 07:30 PM
Raul@Stealth Automotive's Avatar
wow 4.56? that is way too low for 35's....you will lose all your top end with those... you dont have to regear but you will lose city driving MPG but gain highway miles.... if you really wanted to regear i would just get 4.10's... heck im doing 4.30's on my truck with 37's
Raul@Stealth Automotive is offline
post #3 of 12 Old 11-23-2007, 07:34 PM Thread Starter
java black's Avatar
thanks for the quick reply, I probably wont regear I would rather gain highway miles, i commute a few times a week with it
post #4 of 12 Old 11-23-2007, 10:45 PM
i feel like slapping whoever started this rumor that we all need 4.56 gears on our diesels ! ! ! !
there is NO NEED for 4.56's ! ! i am running 35" tires and i still have my 3.73's and i can leave 4 black streaks in the road when i launch. my truck does not have any problem getting up and going.
if you are planning on doing A LOT of towing, you can step down to 4.10, dont even consider 4.30's unless you plan on going to a 37" tire.
to put things in perspective. 05 6.0 with 4.56 gears will spin 44" tires thru 3 gears going down the road ! ! i know because that's my boy's truck ! !
LvTitan is offline
post #5 of 12 Old 11-23-2007, 10:46 PM
raul -- just saw your post. you are certainly on the right track. i cant believe anyone would recomend 4.56 for a 35" tire
LvTitan is offline
post #6 of 12 Old 11-24-2007, 04:06 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
I would if it was for a gasser
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #7 of 12 Old 11-24-2007, 04:24 AM
duct tape & zip ties
bigcountrysg's Avatar
I aggree with you Dave. Gas truck yes, diesel truck no. The only time I would consider regearing my truck is if I went over a 35 inch tire.
When I had my 85 Chevy with a 454 in it. I was running 40 inch ground hawgs on it. I had 456 gears in that and I could smoke them tires easily.
My brother had a 92 GMC 1500 and was running 38 inch super swampers and had 456 gears.
But on a diesel gears are not needed unless you are over 35 inch tires. 4.10's would not be bad but for the cost out wieghs the benefit.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #8 of 12 Old 11-24-2007, 08:20 AM
ebusa's Avatar
Not needed. However, I would get a programmer to bring back any power you might have lost. I'm running the flashpaq on just the Econo setting and it feels like I have the stock tires with alot more power.
-Evan
Semper Fi
2005 F350 Crew Cab LB FX4 Lariat
Loaded-Leather, Sunroof, 06 Chrome Package
5'' Tuff Country Lift
Toyo MT's 35's with Race Line Renegade 20's
ARP Studs, EGR Cooler Delete, Coolant Filter
MBRP 4'' Exhaust Turbo back, No Cat
SCT X3 Tuned by TSD & IDP
Stock Airbox, NON-MAF Truck
GT3788VA POWERMAX Turbo
DiProcol Optix EGT & Boost Guages , Scangauge II
ebusa is offline
post #9 of 12 Old 11-24-2007, 05:43 PM
i have stock gears and 35" tires. i have NO problem running a low 13quarter mile and i can smoke them thru several gears.
LvTitan is offline
post #10 of 12 Old 11-24-2007, 06:12 PM
Lonno's Avatar
I had 4.56 in my 2000 f250 gasser and that worked great. I just put in 4.30 on my psd with 37" tires and for me it works great but if I did a lot of highway driving I would of gone with 4.10's. Definately not 4.56's, you will regret it.
1970 F250 Crew Cab rebuilt/restored w/Cummin s 4bt
8v, M5R2 Tranny, VE pump, DennyT stage 2 pin, M&H Dynamic Timing, 3200k gov spring, Hx30/Hx35 Twins, 40hp styx, smoke screw screwed, star wheel cranked, Hydroboosted
91 Gillig Phantom, Converted transit bus, 6v92 Detroit Diesel
6500 Watt Diesel Generator on board
All Diesel
All Day
Lonno is offline
