gearing - Ford Powerstroke Diesel Forum
Old 11-21-2007, 07:19 PM
gearing
How do I find out what my axle ratio is? I have a 06 F350. I am assuming 4:10. Thanks for any help.
Old 11-21-2007, 07:53 PM
tag on the rear end or I think there's a sticker under the hood. 4:10's in mine what kind of RPM you running in OD at 70mph?
Old 11-21-2007, 08:13 PM
Don't know yet. I will let you know tomm.
Old 11-21-2007, 08:46 PM
Should be 3.73 if you have an SRW.
Old 11-21-2007, 09:53 PM
It is the DRW.
Old 11-22-2007, 07:01 AM
Yea, probably 4.10 unless you have the tow boss, then it would be 4.30.
Old 11-22-2007, 07:18 AM
Almostdunfukinwidit
Check the tag on the rear or the build stick on the door. It will tell you
Old 11-22-2007, 09:10 AM
Im at 2250 at 70..... so I got the 4:10.
Old 11-22-2007, 05:06 PM
Just spit balling here does anyone have a ballpark figure on re-gearing a F350 to the 3:73 gears. Just curious. Its 4x4 so both the front and rear would have to be done I assume.
