addidives?
who is using what addidives? what kind do you like better than others?
I use Power services- Diesel Kleen products. I've used them in 4 different trucks over the past few years and have had good results.
i use the RBP addidive. i like it alot i used diesel kleen but it dident reduce smoke like the rbp one does
been using the same thing in mine since I got my truck
MPC FT-10, Enertech Enerfuel, Summit Diesel Conditioners. We use the last two in our Diesel Generators at the Nuclear Power Plant I work at, but were going to be switching to FT-10. You can't buy them in your local autoparts store, but I'll bet my truck they will work better than any of the stuff you can buy off the shelf. the last one is made by wellworth products which buy its base chemcials from Enertech Labs. Enertech require you to buy from reps while Wellworth sells there stuff online. There both essentialy the same product.
Diesel Kleen.
I use the large 128oz liquid laundry soap bottle that has the push button dispenser on them. just buy a small bottle of DK every week and pour it into the laundry bottle and keep your reserve up. Then keep the small DK bottle and fill it up from the push button dispenser on the laundry bottle to pour in the truck. I've had diesel kleen in it for a while and it works like a charm....WASH OUT THE L. BOTTLE BEFORE YOU USE IT. I keep degreaser (purple stuff from Wal-Mart) in another bottle in the garage also to fill up the hand spray bottle...its a great dispenser. Another benifit is, if you set the bottle dispenser end up in your tool box it wont leak! Like RVing? Welcome to RV Crazy A site for RVers |
i used to use Ford cetane boost i get good mileage with,,, but i got a bottle of FT-10 from Larry at DPP and thats my new choose meow!!!! im getting 1-1 1/2 mpg more NOW!!!!! call em up and try it out!!!! THANKS AGAIN LARRY!!!
Probably gunna get flogged for it, but I run ashless 2stroke oil, Powerservice when its cold to keep from gellin, and every now and then I get froggy and smash some lucal injector cleaner in there. I've had good luck with the 2 stroke oil, one ounce per gallon, picker up roughly 1.5 mpg, and the injectors sound quieter.
I run the Stanadyne performance formula and love it. But I might have to get a bottle of the FT-10 from Pat and Larry
I use Howes meaner cleaner ADDITIVE in mine for lubricity.
