Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 11-16-2007, 04:47 AM
GDT GDT is offline
Newb question
I just recently bought my first diesel, and have a few questions that over time I will ask the memebers here. For now, i was wondering about oil changes. The price to have the dealer do it is pretty steep, so I would like to do it myself.
My question is this, I know that on the diesels you should fill the oil filter with oil prior to installing, but on this motor I think the oil filter is on top. That would be a problem, I would think that this is not required on the 06 motor.
Am I correct or not?
Thanks
No need for now, everything was just done, oil, fuel filters, air filters and tranny, egr.
Old 11-16-2007, 06:16 AM
npccpartsman npccpartsman is offline
Since the oil filter housing has a drain valve that opens when you remove the lid I'm not sure that it would even stay in. I've never done that to mine and never had any problems--105K. Just change it every 5K miles with good oil and Racor manufactured filters (Motorcraft FL2016, Fram CH9549 are easy and available at Chinamart). Non-Racor filters can cause you problems because of the way the oil bypass is manufactured and patented in the filter housing.
Old 11-16-2007, 06:28 AM
HorseMover HorseMover is offline
You are correct - the oil filter is on top. Just drain the oil - replace the filter element - and then add your oil. You are just replacing the filter element on the 6.0 it isn't a self contained filter so you can't pre-fill it.
Old 11-16-2007, 06:37 AM
GDT GDT is offline
k, thanks. I was pretty sure it would make a mess and could not for the life of me see how you could do it with the 6.0. others yes, but not this one.
Old 11-16-2007, 06:57 AM
20046.0PSDX 20046.0PSDX is offline
GDT,
The only thing you need to oil during the filter change is the oil filter cover o-ring. Apply a light coating to it prior to putting it in the cover. Some say this isn't really necessary but I'd err' on the side of caution.
Here's a link for the change that pretty much covers it CHANGING ENGINE OIL
Amp
Old 11-16-2007, 10:09 AM
Marv Marv is offline
I wouldn't sweat it too much man...it's easier than you think.
I was concerned at first, being this is my first diesel, but it's pretty straight forward.
Good luck!
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
