Alternator - Ford Powerstroke Diesel Forum
Old 01-17-2013, 09:43 AM
Alternator
I got my dc engineering alt, and it says cut the factory harness and wire the yellow the the yellow but there isn't a yellow cable in the factory harness. Alternator-imageuploadedbyag-free1358448182.578984.jpgAlternator-imageuploadedbyag-free1358448217.833640.jpg
Sent from my iPhone using AutoGuide.com Free App
Old 01-17-2013, 09:55 AM
That's weird. I didn't have to modify anything when I installed my DC Power alternator.
Old 01-17-2013, 10:24 AM
Re: Alternator
Same here. Where did you buy it?
Sent from my GT-P5100 using AutoGuide.Com Free App
Old 01-17-2013, 10:30 AM
Alternator
Directly from them.
Old 01-18-2013, 07:51 AM
Alternator
Alternator in, batteries tested out ok, still getting 6,7,8 volts on cold start crank.
Old 01-18-2013, 08:31 AM
Are you reading this voltage directly from the batteries while cranking or are you going through the OBD port?
Old 01-18-2013, 08:35 AM
Alternator
OBD port.
Old 01-18-2013, 08:52 AM
I would check from the batteries themselves, you might be getting an erroneous reading; unlikely but possible.
Old 01-18-2013, 08:56 AM
Alternator
Maybe, but the truck barely started this morning. I just got both batteries tested and they both came back good for CCA and voltage.
Old 01-18-2013, 08:59 AM
those instructions are strange
but if your dropping that low on crank you have either bad batts/bad starter or some other wiring issue IMHO
