Popping in the front end when turning? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-16-2013, 03:09 PM Thread Starter
I noticed a popping sound when I turn the truck. It almost sounds and feels like when you leave it in 4x4 and turn on the pavement. It is not in four wheel drive as far as I know the hubs are in the auto position and the selector switch is in 2wd. It happens either way i turn. What could be the problem?
Will
2004 F-350 Lariat Crew Cab FX4, Dark Grey, T3 Front and Rear replacement bumpers, Fumoto valve, Diamond plate running boards, Zoodad mod, Dieselsite coolant filter w/ ELC, Blue Spring Mod, LED cab lights, Edge Insight CS, SCT SF3, PHP FICM/ECM rollback, Sinister EGR Delete, 6.4 Banjo Bolts, ARP head Studs, Zone Offroad Leveling Kit, CCV Mod, Straight Exhaust, S&B intake, Atlas 40, 295/75R16 BFG,
fishmanwill is offline
post #2 of 6 Old 01-16-2013, 03:16 PM
DoubleDpsd's Avatar
A number of things...ball joints, tires rubbing wheel well or leaf springs, wheel bearings, or any of the other suspension components used to turn the vehicle. Basically a shot in the dark without a video that demonstrates the sound.
Sent from my phone
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #3 of 6 Old 01-16-2013, 03:18 PM
soccerman's Avatar
I had similar issues. Try looking under the hood on the passenger side there is a little box. I was told it is the vacuum system for the 4x4. I had a broken wire on the wire harness. That would be my next place to look.
2006 F350 Lariat
TowBoss Package
Front & Rear Camera
High Idle Mod
Rear Flood Lights
58V Swamps FICM
Remote Start
Straight Pipe
HID Head Lights
BD Heavy Duty EGR Cooler
Blue Spring Upgrade
STC fitting Upgrade
New IPR
Standpipes/Dummy Plugs
Lockpick
soccerman is offline
post #4 of 6 Old 01-16-2013, 03:23 PM
All because your hubs are in auto and the switch is in 2wd does not mean that your hubs are unlocked. The hubs (if they are stockers) are operated by the vacuum pump and some switches. The vacuum line to the hubs may be clogged or a switch is not operating properly and your hubs are staying locked. Jack up the front of the truck, leave the hubs and switch just like they are now, and turn the wheel by hand. If the driveshaft turns then they are still locked. If that is the case I will put money on you u-joints on the front drive shaft are bad.
Sent from my DROID RAZR using AutoGuide App
2012 F250 Lariat CCSB FX4, Gooseneck and 5th wheel prep package, H&S Minimaxx, 5" AFE SS straight pipe, EGR delete with factory EGT sensor, 35" Toyo MT's on stock rims, and Bilstein 5160 shocks.
thomaslord84 is offline
post #5 of 6 Old 01-16-2013, 07:18 PM
Same thing happens to my truck every now and then. On mine it's because the 4x4 doesn't fully disengage so I have to manually turn the hubs to 4 wheel then back to auto. Usually fixes it after a couple tries
2004 F250 FX4, ARP Studs, EGR Delete, Blue Spring, SRLXX Extreme
Wolf50 is offline
post #6 of 6 Old 01-16-2013, 07:32 PM
The reason that I put warn hubs in mine was because the stockers never would disengage and it wore out my u-joints.
Sent from my GT-P5113 using AutoGuide App
