Headlamps - Ford Powerstroke Diesel Forum
Old 11-14-2007, 07:29 AM
Headlamps
Does anyone know if the '05 F250 headlamps will fit in an '04
I don't want to make it into a major type swap, but if it's a "plug n play" type deal I might go with it.
I've looked around, but really have gotten mixed answers.
THANKS
Old 11-14-2007, 07:37 AM
not sure, you may have to change some structural things. i know you can convert the whole front end over easily just try to do that, looks better anyway,
Old 11-14-2007, 09:27 AM
Served Our Country!
From what I've read about it, you'll need to do some cutting on your stock headlight header to make the '05 headlights fit, or you can replace your stock '04 headlight header with an '05 one. New ones go for about $240.
Old 11-15-2007, 12:19 PM
THANKS for the info.
If it was just a simple swap, then I'd go with it.
I'll probably just keep what I have.
