Ready for 1st mod, opinions - Page 2 - Ford Powerstroke Diesel Forum
  #11 (permalink)
Old 01-14-2013, 05:05 AM
Hey guys i ordered the IPR filter. I didnt get the one with the manifold, so i saved 70 bucks. After looking at the forum where people show what was coming out of their filters i agreed this was a good place to start. How do you clean all that gunk out of the filter to re-use it?
  #12 (permalink)
Old 01-14-2013, 07:09 AM
Rinse it with water. Some people soak it in simple green, purple power, you know some sort of degreaser. Then do a final rinse with some distilled water and put it back together.
  #13 (permalink)
Old 01-14-2013, 08:20 AM
Just jumping on the wagon here.....where is the best place to buy a coolant filter.....and how hard is the install
  #14 (permalink)
Old 01-14-2013, 08:26 AM
The best filter is the IPR coolant filter. It's a stainless media and requires only cleaning. It's reusable. It's also on average, $100 more than the rest on the market, but you never have to buy a filter cartridge ever again.
  #15 (permalink)
Old 01-14-2013, 08:52 AM
Onebadcoastie,
If you bought the same filter as me, did you set it up the prefered way where it doesnt effect the heater if clogged or as a inline full flow system, filtering 100% of the coolant?
As far as the install goes it looks pretty easy, mounting the filter in your engine bay and using hoses and hose clamps.
  #16 (permalink)
Old 01-14-2013, 09:15 AM
Originally Posted by Jay06f250 View Post
Onebadcoastie,
You can call me Shack. It's my nickname (also in my sig)...lol... I ran mine to my heater core hoses in what's commonly referred to as a bypass setup. If I turn the A/C on max, it won't circulate coolant through the filter. I also don't have an OEM oil cooler so it's not a concern for me. Mine is mounted just like they show on the website. When I get back from florida, my plan is to relocate to somewhere sturdier in the truck. That inner fender works well but is flimsy sheet metal. The corner of the filter assembly in my case rests on the vacuum canister to aid in supporting it.
  #17 (permalink)
Old 01-14-2013, 06:02 PM
what oil cooler do you have, hell i want to know all your goodies if you dont mind. I want to know how to make my truck the most reliable i can get it. If you have an oil cooler other than the one from BPD i wanna hear about it.
Thanks Shack (Diesel)
  #18 (permalink)
Old 01-14-2013, 06:35 PM
I have the BPD remote oil cooler, Odess cylinder heads, Ford Blue Spring, No Limit CAC, 175cc/stock nozzle injectors, S&B intake, ....you know, just a few little goodies. Once I get back from a work related trip, I'll be modifying my fuel system. I also have the Looney Wild tune from Vivian and SRL+ from Matt.
  #19 (permalink)
Old 01-14-2013, 06:46 PM
so you have a coolant filter plus the bpd oil cooler, cool, i know it said you didnt need one, you just have the extra protection
  #20 (permalink)
Old 01-14-2013, 06:57 PM
The filter was installed before I decided to purchase the BPD kit. After having it, I decided to keep it. It will help pick up ANY debris in the system including casting sand should there be any and it's not hurting me to run it.
Tags
bulletproof, egr delete, mods
