stereo replacement - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-12-2007, 08:27 AM Thread Starter
Cyclist 06's Avatar
stereo replacement
How hard is it to swap the factory stereo for a new cd dvd nav system stereo? I was thinking of doing it myself but don't want to get in over my head. I'm no mechanic or stereo guy but did do all my gauges and installed my cab lights and fender lights myself. What is a good system at a decent price? I would be willing to spend around $600.00 for a new system. Thanks for any advise. (06 F-250)
Scott
Jason topper
305/55/20 Pirelli ATR's
20x9 Diamo DI8
Pioneer Avic D3 nav/dvdcd/stereo/camera/ipod
JL ft speakers
window tint
Custom Gauges by Speedhut
4" Magnaflow SS Turbo back exhaust
Superchips Flashpaq #1805
cowl induction hood
crome differential cover
Bilstien 5100 Shocks
cab roof lights from Ford (smoked lenses from Recon)
Recon fender lights
Recon tailgate light bar
Fumoto oil drain valve
Cyclist 06 is offline
post #2 of 5 Old 11-12-2007, 09:48 AM
JohnO's Avatar
I'm finishing up a stereo swap on my 06 F350. Got a Pioneer AVIC-D3, good unit. It set me back $700 on amazon. Only downside with the D3 is that you have to pull the nav disc to play a CD, but since I have an ipod attached, I didn't care about that. Here's a few things I learned:
Pulling the dash panel is unbelievably simple. Just grab the top lip and tug on it a few times, it pops right out. Same for the door panels if you're replacing speakers. Very simple.
You will need the nav unit, plus an install kit, plus a wiring harness plug. You'll also need a 1/4 drive socket wrench set.
Wiring up the plug you bought to the Pioneer nav unit was simple. For the most part, the color codes matched. Solder the wires together! This is a diesel engine, and they do vibrate.
If you have steering wheel volume controls, you can get a unit to get them to work with the D3.
Getting the old CD player out was simple - held in place by two screws.
For the most part, it was a simple install. Only trouble spots were finding the speed sensor (too many gray/black wires under there) and finding the reverse indicator wire (trial and error). And when you take off the red reflectors on the door to get the door panel loose, be careful. It's real easy to break the tab off of the end.
JohnO is offline
post #3 of 5 Old 11-12-2007, 10:10 AM
COLLEGE KID
lifewitlooie's Avatar
Send a message via AIM to lifewitlooie
Its a great idea to solder but if you dont solder, just make sure you make really good connections. if you dont feel like doing it.. shouldnt cost you more than 20-40 bux to get someone to do it for you
lifewitlooie is offline
post #4 of 5 Old 11-12-2007, 01:10 PM Thread Starter
Cyclist 06's Avatar
sounds easy enough
Thanks for the input guys
Scott
post #5 of 5 Old 11-13-2007, 06:08 AM
outbackwelding's Avatar
I recently put in a DVD player with a 7" pop-out screen in my '05 that I got off of e-bay for cheap, install was very simple thanks to a dash instal kit and a wiring harness adapter that I picked up locally. Using the wiring adapter you can connect all the wires from your stereo to the adapter on your workbench and once the factory unit is out, you just plug in the new adapter, and then your almost finished. There are hundreds of websites that you can Google to get help if you need it. But, if your looking for a one stop shop, go to Crutchfield.com. When you buy your player from them, they include any instal kits, wiring plugs, and detailed step-by-steo instructions to help you get the job done yourself.
'05 F-250 CC FX4
Edge Juice w/Attitude
In dash Pioneer DVD Touchscreen
Overhead 10.5" monitor
Custom grille guard (Built in my shop)
Hitches for gooseneck and fifth wheel
Zoodad, Foglight override, High Idle mods
Cat and Muff delete
35" Nitto Terra Grapplers
outbackwelding is offline
