torqueshift fluid capacity ? - Ford Powerstroke Diesel Forum
Old 11-11-2007, 10:33 PM
I just hiit 30,000 miles and need to change the tranny fluid.changing the frame mounted filter and draining the pan how many quarts of mercon sp do I need to refill it?
Old 11-12-2007, 04:46 AM
About 20 quarts I believe. EDIT: It was about 20 quarts for me b/c of a little flush then fill!!! Very important and I left that out. Sorry 'bout that.
Last edited by tabraha; 11-12-2007 at 08:11 AM. Reason: Left out some important info!!!!
Old 11-12-2007, 05:22 AM
The manual for my '03' says 17.5 quarts including remote filter change for the 5sp Torqshift. Page 279 in my book.
Old 11-12-2007, 06:25 AM
i've changed the fluid in torqshifts a number of timer and never used more than 8.5 quarts, but that is just with removing the drain plug & filter and letting it drain for about three hours(i've never drained the torque converter)
Old 11-12-2007, 09:04 AM
Below is a link to a good HOWTO for the Torqshift fluid change. BTW, I just came back from my local dealer and they want $195 to flush the Torqshift.
Truckblog - How-To Flush Ford's Torqueshift Transmission
Old 11-12-2007, 10:10 PM
my manual says 17.5 also,but thats total capacity.I figured 8-10 for draining the pan and changing the filter but wasnt sure.IIRC there is not a drain plug in the converter on these.
Old 11-13-2007, 04:48 AM
Nice find on the write-up! Your dealer's not to far of from mine. They wanted $175 for a flush and fill.
Old 11-13-2007, 05:36 AM
Hi Tabraha, thanks.
