Trans Temp??? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-11-2007, 12:10 PM Thread Starter
Trans Temp???
ok my trans temp gauge is hooked up and i see temps in the 200-210 range driving on the highway and even just parked i stays that high. something doesnt seem right. id this too high for temps? i know on my dodge i couldnt beat the trans enough to get the temp to 180.
08 F350 cc/lb lariet
6" lift Pro comp rims/tires
sparten 310
Stacks
SOLD
06 F-250 Lariat 4X4
6" lift 35" pro comps
MBRP 4" turbo back missing the kitty & muff
Full gauges
Sct X3 with DJ's Looney Tune
stacks and studs
jb903 is offline
post #2 of 12 Old 11-11-2007, 12:14 PM
Raul@Stealth Automotive's Avatar
that is way high.... you dont want to go over 210... i like to keep mine at under 170...either your temp probe is off or could mean you have other problems with the trans. if everything seems alright i would get a secondary trans cooler with a built on fan.
Raul@Stealth Automotive is offline
post #3 of 12 Old 11-11-2007, 12:44 PM Thread Starter
i just had the trans fluid and filter changed and the fluid looked o.k. the trans shifts perfect. i know the dash gauge isnt too accurate but it cant be that far off im thinking. well ill try another temp sending unit and see if that helps.
sparten 310
Stacks
SOLD
06 F-250 Lariat 4X4
Full gauges
stacks and studs
jb903 is offline
post #4 of 12 Old 11-11-2007, 01:13 PM
the stock one is useless.... my stock will always be at normal with my auto meter one being at anywhere from 150-200 with the stocker saying normal.... i added a secondary trans cooler with the built on fan and havnt gone over 180 since then.... here is a couple of pics of it...
post #5 of 12 Old 11-11-2007, 02:33 PM Thread Starter
well i just put another temp probe in and its saying the same thing. 200-210. man that doesnt seem right. well im gonna try a putting on that trans cooler and see what that does.
sparten 310
Stacks
SOLD
06 F-250 Lariat 4X4
Full gauges
stacks and studs
jb903 is offline
post #6 of 12 Old 11-11-2007, 02:53 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
something doesnt seem right especially since the torqshift cooler is pretty big the way it is. What were the temps at before the flush? Was mercon SP put back into the tranny
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #7 of 12 Old 11-11-2007, 04:47 PM
Maybe a blocked or partially blocked cooler? those temps seem way too hight to be normal
post #8 of 12 Old 11-11-2007, 06:56 PM
nightworker
Guest
Posts: n/a
Quoted: Post(s)
temps
Daily driving I run 130 - 170... towing 185 is the highest ist ever got.
post #9 of 12 Old 11-11-2007, 06:59 PM
hey bud i just added these trans coolers to my site.... Stealth Automotive. Oil Coolers
post #10 of 12 Old 11-11-2007, 07:02 PM
Slacker
Evil Eye's Avatar
Quoted: 193 Post(s)
Feedback Score: 4 reviews
I agree. Those are way too high. Does your tranny cooler get warm? Sounds like it might be the problem.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
