fuel additive - Ford Powerstroke Diesel Forum
post #1 of 19 Old 11-09-2007, 01:38 PM Thread Starter
matt_05stroker's Avatar
fuel additive
I was wondering if any of you ever used a fuel additive or injector cleaner in your 6.0 ? if so what type/brand.
matt_05stroker is offline
post #2 of 19 Old 11-09-2007, 01:43 PM
Desert Shield/Storm Vet
vitalidle's Avatar
I have a 7.3, but I think its a good idea to run a fuel additive. Ford has one, also Powerservice, and Standyne are some good ones off the top of my head
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 19 Old 11-09-2007, 02:14 PM
feusaf's Avatar
I put 8oz of Diesel Kleen in my truck at every fill-up. You can get it at Wal-Mart for about $6-7 a bottle back in the automotive section. I hear the gray bottle used for summer and the white during the cold months.
Can't say that I've really seen much of a difference in the past 5k miles, but who knows...maybe my injectors are already clean
Jim S.
2002 Ford Excursion XLT 7.3L Powerstroke
S&B Intake
MBRP 4" Turbo Back
Bully Dog Triple Dog GT
Kenwood In-Dash Nav
05 Grill and Headlight Conversion
Ranchhand Legend Grill Guard
MB Stryker 16x9 Wheels
Yokohama Geolander 265/75R16 next is 33's
Waiting on a Remote Start and a Home-made TruckVault
Clovis, NM
feusaf is offline
post #4 of 19 Old 11-09-2007, 02:53 PM Thread Starter
thanks guys, I've seen the ones at wal-mart, I guess anything that boosts the cetane rating helps.
post #5 of 19 Old 11-09-2007, 04:32 PM
EODguyJake's Avatar
Quoted: 7 Post(s)
I use the Lucas Oil additive that is good for diesel or gas engines. It does all the injector cleaning and other crap...It doesn't have a cetane booster, but it smooths things out a lot.
2015 F-350 6.7L, CCSB, SRW, FX-4
2004 F-350 6.0L SRW XLT Sport, Ex cab, SB, FX4-Gone after 10 years as original owner
There are very few personal problems that can't be solved by the proper application of high explosives!
Initial Success or Total Failure-EOMFD!
EODguyJake is offline
post #6 of 19 Old 11-09-2007, 04:54 PM
proline2's Avatar
whats a good fuel additive for 7.3
-22'' Fuel Hostages
-35'' Nitto A/T
-Leveling kit
-Edge Evo just for monitoring
-H&S XRT pro
-AFE cold air intake stage 2
-Flo Pro delete pipes and egr delete
-Roll and Lock
proline2 is offline
post #7 of 19 Old 11-09-2007, 06:11 PM
poker5150's Avatar
I use Amsoil Cetane Booster and Amsoil Diesel Concentrate at every fill-up.
2004 F-350 CC Lariat 4X4
5-in Pro-Comp lift
18-in American Eagle wheels
35X12.5X18 Pro-Comp Extreme AT's
Billett grill
SCT tuned by Innovative
4-in MBRP exhaust w/cat delete
Innovative's intake elbow
Zoodad/Firestone airbags
Boost, Tranny, EGT gauges on A-Pillar
1000 Watt Pioneer sound system
poker5150 is offline
post #8 of 19 Old 11-09-2007, 06:12 PM
vitalidle's Avatar
Any of the three I listed, or what everyone else has listed will work
Auto 93,000 miles
DP Tuner F5
post #9 of 19 Old 11-09-2007, 06:20 PM
WILLIAM LORCH's Avatar
Send a message via MSN to WILLIAM LORCH
Staydine is about best, Power Service is good one and readly avial at NAPA or service stations.... I pefer stayine becuse those folks MAKE fuel pumps and overhaul injectors do most stuff to fuel systems ........ Bill
WILLIAM LORCH is offline
post #10 of 19 Old 11-09-2007, 06:28 PM
HorseMover's Avatar
Quoted: 29 Post(s)
I use PowerService (Diesel Kleen) primarily due to its availability- just picked up the white stuff tonight as it is getting colder here now. Matt 05 I see you are from Warren - I am up in the Erie area - I hunt down in the Warren area from time to time.
2012 F-350 CC Lariat Dually
HorseMover is offline
