installed block heater cord - Ford Powerstroke Diesel Forum
Old 11-04-2007, 05:19 PM
now when i plug it in to the extension cord it seems kinda lose and if you wiggle it or move it just a little it sparks blue and sizzles and pops...its not full out sparks its hard to explain...i got the cord from the dealership and it didnt have a lock ring or anything just some gold ring thing on the end that plugs into the block...is that suposed to tighten down somehow because i can just spin it all the way around...could it be my extension cord? ill try a new one when i get back from michigan...thanks in advance....
Old 11-04-2007, 05:24 PM
Desert Shield/Storm Vet
Could be the extension cord. Is it a heavy duty cord?
Old 11-04-2007, 05:30 PM
ya its a big one....do u know if i should be able to spin that gold piece or not? i thought it came with one of the lock rings that looked like a nut...
Old 11-04-2007, 05:32 PM
Im not sure to be honest with you I never have taken a close look at them. Someone Im sure will chime in with a good answer
Old 11-04-2007, 05:36 PM
alright thanks....
Old 11-05-2007, 11:32 AM
mine came with what looked like a nut,I plugged the cord into the block then tightened it, It didn't turn a lot but it did snug down. I use a heavy duty extension cord, and its a tight fit from the block heater cord the my extension cord.
Old 11-10-2007, 02:04 PM
mine came with what looked like a nut, I plugged the cord into the block then tightened it, It didn't turn a lot but it did snug down. I use a heavy duty extension cord, and its a tight fit from the block heater cord the my extension cord.
Ditto on mine. I read somewhere that not all years use the locknut. Based on the quote above and that I used the locknut on mine I'd say 2005's do.
Old 11-10-2007, 02:10 PM
ya mine didnt have that..just that gold thing with 2 long edges on it..i pushed it in as tight as i could...but the gold thing just spins it doesnt tighten...
Old 12-12-2007, 05:01 AM
heater cord lock ring
Hey Guys. I just finished installing the Ford dealer purchased cord on my 06 F-250. The heater which is already in the block has 2 prongs set into it surounded by a threaded boss. I have seen 2 types of cord - one which has a chrome colored retaining ring that matches the threads and gets tightened after the cord is plugged in - or the one like mine that has a gold colored ring with 2 prongs - this ring gets pushed stright on without turning. As you push the ring on - the prongs will snap on the threads until it bottoms out and the ring locks the cord end on the heater.
