Taking a break from egr delete.... - Page 3 - Ford Powerstroke Diesel Forum
  #21 (permalink)
Old 01-01-2013, 07:02 PM
Powerstroke Techie
Feedback Score: 3 reviews
I don't fold, I lay legs sticking straight out. Not a problem except your stomach gets a little red.
  #22 (permalink)
Old 01-01-2013, 07:11 PM
MAD - Modification Addict
Feedback Score: 8 reviews
^^ THIS ^^ LOL I was gonna say the same thing I lay on top of the engine compartment and my knees are laying on the top of the grill with my feet hanging straight out. LOL probably looks pretty funny to someone walking or driving by but oh well, it works.
  #23 (permalink)
Old 01-01-2013, 07:22 PM
11mm gear wrench! I can do an egr delete in 3 1/2 hrs without air. Although a 3/8 cordless impact with a variety of extensions and wobbly sockets makes life easy
Sent from my iPhone using AutoGuide.com App
  #24 (permalink)
Old 01-03-2013, 10:59 PM
I have gone high-tech.....a thick wool blanket, folded 3 times and laid across the front above the radiator. Actually comfortable! I just need to find a pillow to make it complete, but the wife would kill me. Sure hope she doesn't discover that after I got 98% of the oil cooler cover clean, the dishwasher finished the job. Came out looking like new, and smells like lemon!
I sure wish Ford had installed a short 'doghouse' access panel as in commercial trucks. Can you imagine how easy the up pipes, turbo and ipr would have been? Mmm...I do have that sawzall sitting over there......
In total contrast to working on the engine.....I was reading through the service manual. Is the heater core really that easy to change? How can that be???? Why didn't they bury it behind the middle of the dash, requiring complete disassembly of everything?
  #25 (permalink)
Old 01-05-2013, 04:53 PM
Just removed my HPOP.....pretty straightforward operation, but a pain in the *ss to reach way back there!
My pump appears to be the original, with the STC fitting. I can see why there's an update for that. The damn fitting feels loose, and you can move it around a lot. My pressure ws fine, I'm just replacing the HPOP as a preventative thing, seeing how the screen was torn and missing from under the oil cooler. (And I don't want to come back in here for a l-o-n-g time.)
  #26 (permalink)
Old 01-06-2013, 05:21 PM
Heater core removed today. That was a refreshingly easy procedure. I ended up pulling the heater core.....remember, preventative maintenance......when I removed the heater hoses, the amount of crud inside concerned me. Worse yet, was what came out of the heater core just when removing the hose. It appears my heater core acted as a huge filter when I did the flush procedure. (Imagine what a flush does to an oil cooler, if you're not changing it!)
Those Ford 'quick connect' heater hose things are....definitely a pain. Laying across the engine bay, half upside down, too small to really get a good handle on it. 20 minutes to get them off. I'll go with old fashioned hose clamps when I put teh new heater core in. Also, I disassembled the factory heater hose, that is crimped onto the metal tube that goes across the firewall. Picked up a 'U' shaped piece of pre-formed 3/4" heater hose that will connect well to the pipe. A Dremel tool made quick work of removing the factory crimped connections without damaging the tube.
A note on the flushing....I did it 'by the book', spending a full day on it with the chemical flush, followed by multiple drain and fills, back flush....thought it has to be spotless inside. Every access to the engine cooling system I have, it looks clean as new. That includes the block heater location....I pulled that to install a new one. However, it seems the heater hoses and radiator hoses do not come clean. They are all coated fairly heavily inside with a white substance. (So all hoses being replaced.) I am betting this was the first flush in 172,000 miles....it had the Ford Gold crap in it as well. Radiator had sediment in the bottom, after I pulled it and dumped out what wouldn't drain.....but otherwise is squeeky clean.
Just waiting for the HPOP to arrive Wednesday....
