Bad alternator? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 01-01-2013, 08:59 AM Thread Starter
Bad alternator?
2006 f250 6.0. Just installed the sct livewire so I can see that the battery voltage stays around 11.8 when the truck first starts up. After about three minutes it bumps up to 13.6~. I have never seen something like this.
JakeG is offline
post #2 of 20 Old 01-01-2013, 09:11 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
The drop down in voltage is from the glow plugs being on, they can be commanded on for up to 120 seconds depending on ambient temp.
Sent from my iPhone using AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 20 Old 01-01-2013, 09:12 AM
I've heard two different stories. One that the ECM doesn't turn on the alternator until the glow plugs are turned off, and another that the 200+/-Amps that the glow plugs draw are keeping the voltage down, and once they cycle off the voltage jumps up.
2006 built 05/05 XLT CC DRW PSD. Captain chairs, sunroof, polished aluminum wheels, 6speed, manual 4x4. 285K miles with 130K problem free miles on new engine.
RatherBNtheWoods is offline
post #4 of 20 Old 01-01-2013, 09:13 AM
On my dual alternator setup, the single one doesn't put out at first, but the second one does., So,,, it's one or the other.
post #5 of 20 Old 01-01-2013, 09:15 AM
Quoted: 153 Post(s)
I see something similar on my truck....usually upon start I'm at the upper 11's or low 12's then after a couple minutes, it goes to 13+. I believe there are 2 things going on here. First, the glow plugs still are on which have a good draw and secondly I believe the programming of the truck doesn't kick on the alternator for charging purposes until a few minutes afterwards. I could have sworn that I read up on this exact thing and after getting the response, I haven't worried about it since.
2017 F350 DRW King Ranch FX4
2004 F350 6.0 - Traded 2/4/17 (Pity the fool who bought it)
jd4010 is offline
post #6 of 20 Old 01-01-2013, 10:33 AM Thread Starter
Seems like the FICM would need as much as possible so it would be up pretty quick. Since having the gauges in front of me, it's a little different. Thanks guys. Any links to a write up on what and how to install a second alternator?
JakeG is offline
post #7 of 20 Old 01-01-2013, 10:38 AM
ZMANN's Avatar
Quoted: 1775 Post(s)
you won't be adding duals to a truck that came equipped with a single without a PCM from a dual truck and brackets /belts/ pulleys /wiring / secondary alternator ETC
ford has a procedure on how to eliminate 1 of the duals but states adding a dual isn't advised and has no procedure on how to do so
We Miss you Ronnie
ZMANN is offline
post #8 of 20 Old 01-01-2013, 10:41 AM
ZMANN's Avatar
FYI the longer you wait after the WTS light goes out the longer you are into the 2 minute cycle so the faster your truck will jump up to full charge
even does it when it's 120 degrees outside LOL
We Miss you Ronnie
ZMANN is offline
post #9 of 20 Old 01-01-2013, 11:33 AM Thread Starter
Excellent info guys thanks. I was thinking for the camper a dual alternator would be nice, but sounds like that's not an easy option. I might look into a single high output alternator. Thanks guys.
JakeG is offline
post #10 of 20 Old 01-01-2013, 06:27 PM
I was thinking there was a dealer kit that they could add the second alternator. The second one isn't controlled by the ECM. It's just a regular ole alternator like my '77 F150 had. 'Cept better and bigger.
